Old 05-30-2004, 08:25 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default Wish me luck
Turbo install is tonight. I hope nothing major happens.
NeaD is offline   Reply With Quote
Old 05-30-2004, 08:30 PM   #2
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
GOOOOOOOOOOOOD LUCK!!! You will need it!!!
Mariano is offline   Reply With Quote
Old 05-31-2004, 01:38 AM   #3
NeaD
Member#: 43371
Hydra User, Blue
Intercooler doesn't not fit.....................
Old 05-31-2004, 01:40 AM   #4
NeaD
Member#: 43371
Hydra User, Blue
compressor outlet points straight at the bellhousing, no way to get the IC pipe on there
Old 05-31-2004, 01:52 AM   #5
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Keep going man. Try hard to make everything work. GO...GO...GO...GO.....GO...........a hell you get the picture
impr25rs is offline   Reply With Quote
Old 05-31-2004, 03:00 AM   #6
65 mustang
Member#: 40682
Man that wrx intercooler just does not fit on the 2.5. Do you have to beat in the top with a hammer or something. Trim the flance where it goes into the intake manifold? Something is not right.
65 mustang is offline   Reply With Quote
Old 05-31-2004, 03:01 AM   #7
NeaD
Member#: 43371
Hydra User, Blue
I'm going to post some pics soon.
Old 05-31-2004, 09:02 AM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, you really should trim both sides. It takes a lot of effort getting it in there, and even more getting it out.
You know the stock Y pipe doesn't fit too, right? It needs to be extended.
Brent
scoobyimprza is offline   Reply With Quote
Old 05-31-2004, 11:27 AM   #9
NeaD
Member#: 43371
Hydra User, Blue
Yeah, I know. We are going to rig something up.
Old 05-31-2004, 12:01 PM   #10
Unsung Boxer
Member#: 37196
Here are my suggestions:
-Yes, the throttle body and the intercooler neck need to be trimmed to make it fit. This is a known issue.
-The Y pipe is also a pain, but depending on who made your pipes, it should work.
-Getting the coupler to fit inbetween the TB and IC is one of the most difficult tasks. Leave the hose clamps off at first. Slide it on, I warn against using lubricant (esp since your shaving the necks down. Lubricant will allow the coupler to pop off all the time). if you MUST use carb cleaner. This will dissappait eventually. DO NOT USE GREASE or WD40. Use a flat head screw driver (or hose pick) to work the coupler around the neck. Once its on, put your hose clamps around it.
-Also note how much play you can get out of the turbo outlet simply by leaving the bolts on the turbo/up/dowpipe loose until its all fitted up. Ive said this before but it can make the difference of fitting and not.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-31-2004, 12:25 PM   #11
NeaD
Member#: 43371
Hydra User, Blue
Thanks for the tips
here are some pics.
Old 05-31-2004, 01:44 PM   #12
2SLO
Member#: 63058
im rigging up some stuff. thanks for the info guys. anyone have pics of modified y pipe? we can take pics of what i rig up tonight.
2SLO is offline   Reply With Quote
Old 06-01-2004, 01:32 AM   #13
NeaD
Member#: 43371
Hydra User, Blue
More pics of what we did today.
Finally.........
Oh yeah.. Here's the wrx.
(my cuz's)
Old 06-01-2004, 01:37 AM   #14
Braybeurn
Member#: 44769
2002 WRX/STi
Its going to blow up!
Braybeurn is offline   Reply With Quote
Old 06-01-2004, 01:59 AM   #15
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
youre going to blow up
Old 06-01-2004, 02:07 AM   #16
kaos200
Member#: 2692
kaos200 is offline   Reply With Quote
Old 06-01-2004, 03:25 AM   #17
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Nice headers Definately get a support bracket on there so they don't crack.
Oh and uh.... nice pipes too BTW. Just do me a favor and no close ups of that 3" down pipe, I don't want everyone thinking I can make them one. Those things are MUCH harder to do than the 2.5"
Chad
93 2.2T
subachad is offline   Reply With Quote
Old 06-01-2004, 04:50 AM   #18
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
WHat FMIC does your Cousin have if I may ask
benjaminetanyahoo is offline   Reply With Quote
Old 06-01-2004, 01:56 PM   #19
NeaD
Member#: 43371
Hydra User, Blue
Bitz, I have a better pic if you want it.
Old 06-01-2004, 01:57 PM   #20
NeaD
Member#: 43371
Hydra User, Blue
Chad
93 2.2T
Don't worry, I'll get more pics for ya.. hehehee...
Old 06-01-2004, 06:00 PM   #21
impr25rs
Member#: 60162
04 Aspen RS
Did you use a wrx cross member for the turbo system, custom fab, or not use one?
Old 06-01-2004, 09:30 PM   #22
NeaD
Member#: 43371
Hydra User, Blue
I am using the stock RS cross member. The up and down pipe are custom made by subachad.
Old 06-01-2004, 09:38 PM   #23
AntonioS
Member#: 23233
2000 2.5RS-T
white
I have a ej20 with a wrx xmember going in next week will the wrx IC work for me? and what modification will require if some need???
AntonioS is offline   Reply With Quote
Old 06-01-2004, 10:00 PM   #24
Unsung Boxer
Member#: 37196
Where the heck is your MAF sensor, that is a 98 right? I dont see how you fit it in between the K&N and the Turbo.... Unless your using LINK
-Jake
Old 06-01-2004, 11:59 PM   #25
NeaD
Member#: 43371
Hydra User, Blue
-Jake
Hydra
Wish me luck at the National Tour KC New England Impreza Club Forum -- NESIC 10 06-19-2001 11:23 PM
Wish me luck-- going to see the last 5 speed WRX wagon in DFW JayP Texas Impreza Club Forum -- TXIC 5 05-05-2001 09:08 AM
Wish me Luck....... Gonna Need it!! Andre Vandenberg Texas Impreza Club Forum -- TXIC 5 03-19-2001 09:16 AM
Wish me luck, buying my RS Safir General Forum Archive 3 02-05-2001 09:05 PM
My injured Subaru is going in...wish me luck. SFsube Bay Area Impreza Club Forum -- BAIC 5 07-06-2000 11:50 AM
