Old 05-31-2004, 10:43 AM   #1
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
Default difference in 02 wrx ecu vs 03 wrx ecu?
just curious, im going for a swap and wondered if they had a minor difference like wire colors or some bs like that.
thanks
-eric
erice1984 is offline   Reply With Quote
Old 05-31-2004, 03:09 PM   #2
speedblind
Member#: 42202
Nope. I swapped my 02 ECU for a flashed 03 ECU and everything's the same. I have heard that you can't go 03 to 02 though.
speedblind is offline   Reply With Quote
Old 05-31-2004, 04:37 PM   #3
3:15wrx
Member#: 47438
SOON STI
Only major difference is the fuel tank pressure sensors which are in the 2003 wrx's, but not in the 2002. If you do a 2.5 swap you'll have to pick the wires out of the wrx harness anyway. Just make sure you have the correct wiring diagrams for the correct ECU and take your time.
3:15wrx is offline   Reply With Quote
Old 05-31-2004, 04:56 PM   #4
Hey_its_Cole
Member#: 55305
I have an 03 in MY02 and i have a p1446 fuel pressure evaporite code. I just ignore it.
Hey_its_Cole is offline   Reply With Quote
Differences in 02/03 zero sports sideskirts vs 06s Gso2k Interior & Exterior Modification 3 01-28-2008 12:06 PM
difference in 02 and 03+ wrx brakes wrxskier18 Brakes, Steering & Suspension 3 04-27-2006 07:23 AM
02 ECU vs. 03 ECU jlogan9 Engine Management & Tuning 2 05-02-2005 12:36 AM
differences in 02-03 motor compared to 04?? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 09-12-2003 09:40 AM
Difference in 02 to 03 clutch adjustment WRX03 Transmission (AT/MT) & Driveline 0 10-19-2002 08:45 PM
