Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-19-2000, 07:05 PM   #1
Mike Riegel
Member#: 394
Post Strange squeak from rear end
Okay, I just turned 50K on my MY98 RS and there is a squeak coming from what I think is the driver's side rear. Odd thing is, the sound only happens for the first minute or so that the car motion after starting it - then it is gone. The squeaking is rhythmic, but intermittent - is has to be something in the wheel realm...
I had a wheel bearing replaced in the same location about 10K ago, but the sound is different from the "bad bearing" noise.
Any thoughts about what I should do here, I really don't want to take it into the dealership to find out that it needs a bit of oil and 5 minutes of work...
Thanks in advance,
Go Scooby!
Mike
Mike Riegel is offline
Old 07-19-2000, 08:47 PM   #2
dandbest
Member#: 1885
2015 Evo
Cool
The squeak you're describing sounds a lot like either a bad bearing or when the bearing was replaced, they didn't put enough grease... There isn't much else that would cause a squeak there.
Hope it helps!
Danny
dandbest is offline
Very strange popping from rear end... beauhawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-18-2009 07:20 PM
Squeak from rear when going over bumps CletusTheDwarf Brakes, Steering & Suspension 6 01-31-2005 03:57 PM
Squeak from rear suspension Achilles38WRX Warranty Issues & SOA Problems 2 01-16-2002 09:59 AM
Squeaking from front end (low speeds) gumball Brakes, Steering & Suspension 1 10-18-2000 08:15 AM
