Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-31-2004, 08:03 PM   #1
Unsung Boxer
Member#: 37196
Default Did some Tuning today
Alright, i did some unconventional tuning today. After months of theorizing, me and my shop forman came up w/ a couple methods of tuning without a dyno or a wideband o2 sensor.
Unfortunatly there is no "hardcore" evidence of improvement, but the feel and runability is leaps and bounds above how ive been driving it.
My main problem is the fact that the car ran soo bad cold. By the time the computer got started up it would be warm.
These are the methods we used:
1. Ran actual fuel injector cleaner. These ej22t injectors are old, so they could probably benefit from it.
2. Disable o2 sensors, to force the ECU to run as if its cold. It is now unable to trim any fuel, so it HAS to run the fuel ratio my Emanage tells it to.
3. Connect Snapon OBD2 scan tool to watch Timing advance, as well as confirm no Fuel Trim. (plus clear CEL from o2 sensors)
4. Connect to Exhaust Gas Analyzer. This will show efficient burns. Combined w/ my EGT guage this lets me know if im too rich or lean.
_________________________
With the car on the rack, I found that I have been running approx 7% too rich at idle. This minor detail really changed my idleabiltiy.
(as well as the injector flush)
Since we dont have a dyno to induce a load, I could only tune low RPM's on the Rack. After that I took the car out. I found that I had it pretty well tuned at WOT. I simply richened it just a bit, and raised boost from 9.5 to 12psi.
As of right now, I hear no signs of predetonation. It took about 5 hours, and runs alot better. I am also running a full tank of gas with a very effective valve deposit cleaner.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-31-2004, 08:28 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
grrrr
Old 05-31-2004, 10:07 PM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
very effective valve deposit cleaner is.....?
I need to give my engine a good flush before I get a tune.
Benny
benjaminetanyahoo is offline   Reply With Quote
Old 05-31-2004, 10:59 PM   #4
Unsung Boxer
Member#: 37196
its made by BG, its called "44K". I normally dont put faith in additives. My foreman had the same scepticism but has personally witnessed it cure misfire problems caused by carbon deposits on the valves.
Im not sure that this was my problem, but my symptoms do point twords it, and its a 13 dollar "shot in the dark"
-Jake
Did some work today :) Adam-18 Rocky Mountains Impreza Club Forum -- RMIC 24 11-24-2008 07:53 PM
Did some Dirt today... STirocket General Community 13 10-31-2005 12:01 PM
Did some logging today... zuczek Canada Region Forum 3 08-14-2005 12:04 AM
did some stuff today joostin420 Interior & Exterior Modification 3 11-06-2004 11:58 PM
Did some mods today - 14mm bolt left, any ideas DanZ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-14-2004 01:01 PM
