Old 06-01-2004, 04:50 AM   #1
awd4ever
Member#: 31573
I found the
meaning of life!
Default intake manifold improvements over the years
I've searched, but was unable to find any benefits to using an STI intake manifold over a 98rs one for my project. Are there are benefits to having STI manifold (besides the color)?
Thanks
awd4ever is offline   Reply With Quote
Old 06-01-2004, 06:07 AM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
No, unless its a ver 8, they are a different design. Side note the ver 8 STis run the same plug in all 4 holes, while the ver 7 with the older manifold runs a hotter plug in number 4...
Old 06-02-2004, 01:08 AM   #3
awd4ever
Member#: 31573
I found the
meaning of life!
i am not sure i follow you.. are you talking about spark plugs? they dont go into intake manifold
Reason i am asking, is i am trying to get the calculations out of the way before I start spending money on parts, and with ~20-22psi planned I want the most volume from intake mani.
Thanks
Old 06-02-2004, 02:24 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
well an sti intake manidold would give you more room for an intercooler.
will the v8 sti manifold fit onto a set of 98 dohc heads? i dont think they will, but what ever.
subiekid is offline   Reply With Quote
Old 06-02-2004, 01:59 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Thanks
Get a worked manifold...
I was talking about the plugs... number 4 runs hotter then the other cylinders. And some belive its becase of the old manifold.
Old 06-02-2004, 07:26 PM   #6
subiekid
Member#: 25516
so does the v 8 sti manifold fit into a set of dohc heads?
Old 06-02-2004, 07:38 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
DOHC heads, well the sti has DOHC heads... I dont know how different they are vs the older DOHC heads. Other then the AVCS...
Old 06-02-2004, 09:49 PM   #8
subiekid
Member#: 25516
Hmm, I always thought the new intake manifolds for the wrx/sti would not fit onto the older DOHC heads. I might have to do some research.
Old 06-02-2004, 10:42 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I have it from a pretty good source that the USDM '98 DOHC EJ25 heads use the same cores as the '97-99 JDM EJ20K's. They are a big bore with different cams, springs and valves. I can't tell you if they used the same manifold or not, but it wouldn't make much sense to make a new manifold for old cores.
I have also been told that EJ207 manifolds do not line up correctly to EJ20K heads, so a V7 or V8 manifold would likely not fit. But the fact of the matter is that on a FI build, the stock manifold is not going to be a major restriction and doesn't neeed any time or money spent trying to figure out a solution for running 20-25psi...
Old 06-03-2004, 10:13 PM   #10
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Extrude honing your existing manifold is really the way to go. Plus with the older manifolds you don't have to deal with all that TGV crap.
no-coast-punk is offline   Reply With Quote
Old 06-03-2004, 10:53 PM   #11
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I thought I remembered cobb doing some flow bench stuff on the old manifolds and saying that modifying the manifold is not really worth it for the minimal power gains. I also seem to remember something about the unequal length of the runners causing different cfm's at each runner making certain cyliners run hotter. Maybe a custom equal length runner manifold is in order- but not for 20 psi. YOu should be fine with the stock manifold at those boost levels.
Drac9 is offline   Reply With Quote
Old 06-04-2004, 06:41 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
I spoke with Josh at Cobb about this last weekend regarding my NA build and that is exactly what he said. He said that when they cut a manifold to access all parts of the runners during porting and then re-welded it together they saw about a 3% gain in flow. Not worth the effort in my mind, especially on a boosted build...
Old 06-05-2004, 12:25 AM   #13
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I thought it was fuel related, what with the rails being parallel and all that.
THAWA is offline   Reply With Quote
Old 06-05-2004, 12:38 AM   #14
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I think you're referring to series. The third cylinder is last in the series configuration. Parallel is what you want in ragards to fuel distribution.
-Brett
ExecNav is offline   Reply With Quote
Old 06-06-2004, 08:22 PM   #15
awd4ever
Member#: 31573
I found the
meaning of life!
thank you guys, this info has been really helpfull. And it goes in line with what local shops told me.
Old 06-07-2004, 03:35 PM   #16
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I wanna see someone get the 04 2.5 RS/TS manifold and take some intake temp readings.....it's GOTTA be colder since it is plastic!
I'd be REALLY interested in the comparison results.
Wedge is offline   Reply With Quote
Old 06-07-2004, 04:07 PM   #17
Drac9
Member#: 9861
One thing that does help these manifolds a lot is phenolic spacers. Cuts manifolds temps a lot.
FS --> RS intake manifold box and the intake box! CoBB_tHiS! Engine/Power/Exhaust 1 03-10-2009 01:05 PM
Is the 2009 WRX that much improved over previous years? xxForgedxx General Community 28 09-10-2008 03:19 PM
What have been the best car names over the years? snvin Off-Topic 83 02-23-2007 09:52 PM
The de-musclification of muscle cars over the years SinisterMinister Off-Topic 42 09-26-2005 09:20 AM
Intake manifold size over the years? (did it get bigger) awd4ever Normally Aspirated with bolt-on Forced Induction Powertrain 0 01-26-2004 05:13 PM
