Old 06-01-2004, 02:17 PM   #1
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Question Understanding the EJ22T PCV System.
I'm asking this here since there isn't much activity at Legacycentral.org, and perhaps someone here might be able to shed some light.
OK. So the EJ22T block has an extra crankvent coming from the center as seen in the pic below, (The STi 2.5L has one also, just a bit further back the block)
Anyways, I found the following Subaru diagram, explaining the routing of the PCV system, if you look carefully, THAT vent goes straight back into the heads! I currently have it teed off to the PCV hoses, and my catchcan is seeing a little bit of oil, which I know for a fact that is coming from that center vent.
I'm trying to figure out a way to route that vent into my SOHC 2.5 heads.
Thoughts?
-Vic
Wedge is offline   Reply With Quote
Old 06-01-2004, 05:05 PM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question nice diagram Vic
hmmmnnnn.......
I'll look at where my hoses are going tonight
Scoobyslack1 is offline   Reply With Quote
Old 06-01-2004, 05:56 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
can you take a pic further back and in better light?
Jay
Old 06-02-2004, 09:19 AM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Thanks Alan.
Jay, I wish I could, but my car is all back together and that part is covered by the alternator. I'll see if I can digup some other peoples project pics.
Old 06-02-2004, 11:40 AM   #5
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
really? http://bbs.legacycentral.org/viewtopic.php?t=16496
THAWA is offline   Reply With Quote
Old 06-02-2004, 02:19 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Yeah, thats a GREAT thread, but really not much info on Hybrids.
Old 06-02-2004, 02:38 PM   #7
Scoobyslack1
Member#: 2780
junk yards rule!
OMGHi2U
just because your car's a freak and there isn't much info out there
so, that means I don't have to look now right?
(like I can talk about someones car being a freak)
Old 06-02-2004, 02:51 PM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
No Alan, I don't think its as freaky as yours.
So when does the A/C system come off??
Now go look under the hood!!
Old 06-02-2004, 02:57 PM   #9
Scoobyslack1
Member#: 2780
junk yards rule!
Cool
AC.......that has been out for a few months, the belt has been off since last summer
I'll be putting the radiator in this month and I'll be down your way on the 15th
Old 06-02-2004, 04:02 PM   #10
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Here is a cutout shot of an EJ22T, you can spot the vent on the left with the U shaped rubber hose on it.
Old 06-02-2004, 04:22 PM   #11
Scoobyslack1
Member#: 2780
junk yards rule!
Question
Vic, which head studs did you use? ARP?
Old 06-02-2004, 05:39 PM   #12
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Nope, stock ones.
Old 06-02-2004, 07:20 PM   #13
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
http://myweb.cableone.net/subiekid/IM001576.jpg
here is a really big pic of the top, not sure if it helps.
subiekid is offline   Reply With Quote
Old 06-02-2004, 10:37 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I talked to Marc Rameriz (aka Xephyr) about this for a bit and he has just capped it. It isn't really needed, so the easiest solution it to just seal it up. He did the same when he swapped out from the EJ22T to the EJ257 a few months ago...
I believe Joe Cox, and Drac9 have done the same on their EJ22T hybrids...
Old 06-02-2004, 11:08 PM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
one post too late hehe... i just capped mine ....
been like that for 2 years...
HOK is offline   Reply With Quote
Old 06-02-2004, 11:24 PM   #16
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Excellent.
I'll give it a try.
Thanks everyone!
Old 06-02-2004, 11:48 PM   #17
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Mine is capped too...
benjaminetanyahoo is offline   Reply With Quote
Old 06-03-2004, 12:26 AM   #18
subiekid
Member#: 25516
what kind of hp/boost are you guys pushing? so did you just cap each head and then the one on the block then cap the pvc valve on the im and then the pipe that goes into the intake just before hte turbo?
Old 06-03-2004, 01:04 AM   #19
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
You don't cap any other breathers.... only the one with the sock over it in your picture....
Old 06-05-2004, 12:30 AM   #20
THAWA
Member#: 44581
3 Boxers 2 AWD
those are intake ports
Old 06-05-2004, 12:57 AM   #21
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
i was just trying to be snide hahahaa cause those are damn clean socks for rags ahahha
Old 07-07-2004, 06:12 PM   #22
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Bringing this back, I was able to find the following diagram in the mess of my files.
So, according to the stock Subaru setup, THAT piping needs to dump back into the heads.
(Time to tap my RS heads)
Old 07-08-2004, 12:46 AM   #23
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
where does fig 072 IA go to... intake?
Old 07-08-2004, 01:35 AM   #24
subiekid
Member#: 25516
it goes back into the intake pipe called "boot B" which connects to the turbo.
Old 07-08-2004, 01:44 AM   #25
subiekid
Member#: 25516
http://myweb.cableone.net/subiekid/pvcintake.jpg
Here is a picture of there the line goes, ignore the duct tape, that is my bypass valve return that broke off.
Diagram for Oil Catch-Can and PCV System 3:15wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 109 07-06-2009 02:15 PM
STI oil consumption & PCV system bikerboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-12-2003 12:12 PM
Disabling PCV system...can it be done juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-17-2003 12:52 PM
Disconected PCV system? azncandyman Normally Aspirated Powertrain 8 10-26-2002 04:03 PM
Trying to understand the WRX (MT) awd system BritDrew Transmission (AT/MT) & Driveline 27 07-30-2002 07:53 AM
