Old 06-01-2004, 03:39 PM   #1
Puckman
Member#: 61554
Default climate control lights and some more
Guys, got a really wierd problem. The lights that light up the actual symbols on the climate control (you know, the vent, the defroster symbol, etc) don't work. The light bellow them that lets you know you what you have selected does work. Also, my crusie control symbol and reardefroster symbol don't light up, but my fog light one does. Has anyone had any similar problems or ideas on how to fix it. You think it might just be a bulb thats blown?
thanks!
Puckman is offline   Reply With Quote
Old 06-01-2004, 04:02 PM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
It seems pretty common for the dash bulbs to go out I'm finding. Here is a link that will help some:
http://www.scoobymods.com/forums/showthread.php?t=91
and:
http://www.scoobymods.com/forums/sho...ght=Dash+Bulbs
Peaty is offline   Reply With Quote
Old 06-01-2004, 09:00 PM   #3
Puckman
Member#: 61554
thanks, hopefully this will fix it!
Old 06-01-2004, 09:03 PM   #4
sha_zapple
Member#: 41012
1998 Legacy L
im 100% sure its the bulbs. cheap, but getting to the old bulbs is a pain.
sha_zapple is offline   Reply With Quote
Old 06-01-2004, 09:42 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
its not that bad.
also a tip, it is easiest to remove the cold/hot cable down on the passenger side, just under the glove box.
subiekid is offline   Reply With Quote
Old 06-01-2004, 10:34 PM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Originally posted by subiekid
its not that bad.
You shouldn't have to remove that.
I found (when playing with an old HVAC unit) that once you remove the electrical connector from the back of the unit, you can just slide most of the unit out (after removing the slider knobs).
There are 2 tabs (one on either side) that you can just lift off with a screw driver (don't pry too hard, as they are prone to snap off) and slide the part with the buttons right out. The only part that is left are the sliders and all the electrical stuff for them.
That also exposes the back of the bulbs so you can just pop them out (actually, they twist out.....).
I have done a bit of messing around with the HVAC unit and found all this out.
IronMonkeyL255 is offline   Reply With Quote
Old 06-01-2004, 10:36 PM   #7
subiekid
Member#: 25516
hmm, well with my car when i took the HAVC out I would not really get to the back all that well. did you try in a 91 or a 95+?
i took a havc out of a 92 and it had way more cable that alowed the unit to pull out more then the 95.
Old 06-02-2004, 02:58 PM   #8
Puckman
Member#: 61554
thanks guys, probably should have added that it's on a 98 legacy. A question for anyone who has done this. Would you recommend using the bulbs obtained from subaru, or should i go with the ones from radio shack?
Thanks
Old 06-02-2004, 03:26 PM   #9
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
The OEM bulbs are a lot easier to deal with but they are on the expensive side. I used the OEM bulbs myself though.
Old 06-02-2004, 03:36 PM   #10
subiekid
Member#: 25516
its not that expensive, it was only like 8 bucks for all 3 bulbs, and if you need the ones for the cruise/fogs/defrost it should be around 20 bucks.
otherwise you have to take appart each little plastic assembly and fit each bulb in. and do all of them at the same time, dont just do one, cause it could be any time that the next one will blow.
Old 06-02-2004, 09:04 PM   #11
sha_zapple
Member#: 41012
1998 Legacy L
I have a 98 and i fixed the cruise and hazard light. I used the bulbs from CT. Putting the new bulbs in the old plastic assemply is pretty easy. Only cost me like, 2 bucks as well
Old 06-03-2004, 01:41 AM   #12
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I need to do this soon, too.
ALL my HVAC and hazard lights are burnt out.
Can these be ordered online? I could maybe just order from subarparts.com
monovich is offline   Reply With Quote
Old 06-03-2004, 01:55 AM   #13
subiekid
Member#: 25516
i think the part numbers are on the subymods site but you have to pay for that site now. i think i still have hte part numbers i will go look for them tomorrow.
Old 06-03-2004, 10:48 AM   #14
Puckman
Member#: 61554
Yeah i had to pay to get the info. Here it is:
For the fog light/cruise/reardefroster:
83426AA040 clear bulb
83426AA051 orange
For the actual climate control panel you need:
2 Short bulbs PN 72351AC061 (Bulb Mode Temp)
1 Long bulb PN 72351AC051 (Bulb Fan)
Old 06-03-2004, 10:33 PM   #15
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
is the Hazard light one of these, or is it another bulb?
Old 06-03-2004, 11:02 PM   #16
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
it's another bulb.
It's in another assemly, I believe.
Old 06-03-2004, 11:49 PM   #17
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
anyone got a part number?
Old 06-04-2004, 12:15 AM   #18
subiekid
Member#: 25516
Sorry, I had to watch my neice all night. I will look around in my room and see if I have the packages still.
I know i have one in my tool box outside.
Be back in a bit.
Old 06-04-2004, 12:31 AM   #19
subiekid
Member#: 25516
hmm, well since i had gone to college my dad had cleaned out the shed, I will have to look tomorrow. I know that there is 3 bulbs, you need one long one and 2 short ones. I will look tomorrow.
Old 06-04-2004, 08:29 AM   #20
sha_zapple
Member#: 41012
1998 Legacy L
READ the scoobymods threads, it has ALL this information.
EDIT: Looks like scoobymods is pay... boourns. There must be a thread around here with the info
Old 06-04-2004, 08:33 AM   #21
NicoGamine
Member#: 57079
2000 Legacy L Wagon
Light green
We can't, it now asks for registration: http://www.scoobymods.com/forums/showthread.php?t=3626
I've posted a mod, so I'll be able to get a free membership, but others will have to pay.
Nicolas
NicoGamine is offline   Reply With Quote
Old 06-04-2004, 02:16 PM   #22
Puckman
Member#: 61554
read up in the post a little bit, and i list the part numbers for everything but the hazard light switch
Old 06-05-2004, 01:34 AM   #23
subiekid
Member#: 25516
OKay i found one of hte lights.
the smaller bulb which you will need 2 of is # 72351AC061
if you call the dealer and ask them they will be able to tell you what the other part number is for the longer bulb. I haveyet to replace the fog light/cruise/rear def lights but i think the blulbs are all the same.
again, you can call your dealer and get the parts numbers.
if anyone needs anymore info just ask, I can try to get all the part numbers if you all want. it will have to wait till wednesday.
cluster and climate control lights 04wgnNJ Newbies & FAQs 4 03-03-2009 10:04 PM
NO dash lights and climate control lights blkbdrx Electrical & Lighting 4 10-24-2003 10:09 PM
Climate controls lighting BluSuby Legacy Forum 18 12-31-2002 03:44 PM
How to replace climate control lights? Snowphun Legacy Forum 4 04-12-2002 01:20 AM
climate control lights iceman Interior & Exterior Modification 4 02-09-2001 06:50 PM
