Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 10-04-2000, 07:24 AM   #1
burr101
Member#: 907
2002 WRX Sedan
Thumbs up Problem, rear diff is leaking.
got under my car to find my bump stops (with no sucess) and i noticed my rear diff was shiney. i felt around the unit and my hand was coated in a light film of oil. the driver's side axle seems to be where the leak is coming from.
is it leaking? or possibly it was "overflow" from the factory (car is only 7 monthes old and have never washed the underside of the car)?
i've already sprayed the rear diff with degreaser and whacked it with the power washer. this way i guess i can tell if it stays dry.
any thoughts?
shaun
burr101 is offline
Old 10-04-2000, 08:21 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Sounds like there might be a small leak. If it had been from the factory, it would have had enough dirt & dust go by it to dry it up by now.
BTW, thumbs up for the problem, huh?
8Complex is offline
Old 10-04-2000, 08:28 AM   #3
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
It will also leak if the vent on top of the rear diff is bolcked - it is a small hole on the top. Otherwise if it still leaks, than you likely have a bad seal.
rao is offline
Old 10-04-2000, 10:03 AM   #4
burr101
Member#: 907
2002 WRX Sedan
Thumbs up
8 complex,
i screwed up... habit is ever so strong . 99.9% of my posts i use the thumbs up.. whoops
i'm going to wait a few to see if i get any more oil.. i checked it this morning and it is dry as a bone.
shaun
burr101 is offline
Rear Diff Fluid leak - 04 STi mavx5 Service & Maintenance 15 09-06-2007 01:40 AM
How can I tell my rear diff is ok? Treefolk Newbies & FAQs 5 07-23-2007 02:52 PM
How can I tell if my rear diff is shot. rs6er Transmission (AT/MT) & Driveline 1 12-01-2006 04:01 PM
30k service problems + rear diff oil change - 2 hrs labor? demi Service & Maintenance 17 05-25-2005 01:44 AM
The Rear Diff is not open is it? SubaruImpreza_power Transmission (AT/MT) & Driveline 8 03-17-2004 02:59 PM
