Old 06-02-2004, 08:15 PM   #1
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
Default air intake temp
does anyone know if the 96 impreza maf has a air intake temp sensor in it? i'm in the middle of trying to wire in link and don't know if i need to get a air/temp sensor or i can tap it off the maf. thanks
scubydrew is offline   Reply With Quote
Old 06-02-2004, 11:07 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
It might have one but then you have to leave the maf in there, which seems lame if you are only using it to measure intake air temp. I think you would need to power it as well.. It's easier just to buy the GM one and wire it in.
Drac9 is offline   Reply With Quote
Old 06-03-2004, 01:12 AM   #3
Unsung Boxer
Member#: 37196
im not sure, because Subaru uses a 3 wire MAF sensor, of which one is ground, one is refrence, and one is signal.
That being said, i dont see where the intake air temp circuit could run seperately.
It is a Hot-Wire system. The first heats up, the second detects air temp, and puts out a voltage, the ECU then reads the difference. This is the point of the Hydra. It uses a MAP sensor and pre-determince figures to determine what a "maf" output should look like.
Good question, sorry i dont know exactly how to answer it.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-03-2004, 01:59 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
hmmm, that is interesting, i never thought that the car would have an air temp sensor from the factory. The tec 3 came with one. Just need to get the ic tapped for it. i think they are fairly cheap. i have hte part number if you want it.
subiekid is offline   Reply With Quote
Old 06-03-2004, 07:22 AM   #5
Drac9
Member#: 9861
The 2000 and up cars have an air temo sensor built into the map sensor.
Old 06-03-2004, 10:48 AM   #6
Unsung Boxer
Member#: 37196
see, w/ MAP sensor its a good idea to have air temp, that way it can see air pressure and temperature, and change A/F based on that.
w/ MAF, air temperature directly affects air flow. The first wire creates refrence voltage, the second one sees how much heat is being taken away as air flows by it. So its not really air temp, its refrence.
-Jake
Old 06-03-2004, 08:55 PM   #7
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
MAF sensors measure air temp. indirectly. There is a circuit in the sensor itself to maintain the wire at a specific temp. If you have a little bit of cool air, or alot of hot air the temperature drop on the film/wire, and the current required to bring it back up to the specified temperature will be the same. It measures density indirectly this way because a little bit of cool air or alot of hot air will have the same oxygen content. Due to the fact that temperature (and the tendancy to detonate) can't be directly measured, this is why the subie MAF ECU's have such agressive and fast spark advance/retard mechanisms.
no-coast-punk is offline   Reply With Quote
Air Intake Temp Gauge? kbahus Water/Methanol Injection, Nitrous & Intercooler Cooling 4 03-28-2007 12:26 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
Air Intake Temp/ aka duct tape mod! orndog South East Region Forum 16 06-11-2004 08:32 AM
