Old 06-03-2004, 01:45 AM   #1
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Default Smallest Turbo
Not sure if this is the right place to ask but ....
What is the smallest turbo there is ?
subaru or non subaru
its not for my car but for another toy
any info would be great
thanks
pistoffjstr is offline   Reply With Quote
Old 06-03-2004, 10:23 PM   #2
Unsung Boxer
Member#: 37196
look for one off of a TWIN turbo application, generally tehy are smaller
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-03-2004, 11:34 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
HEHE what do you have planned? a turbo lawn mower. The smallest turbo i have ever seen is one from a EA81t subaru brat. Also some motorcycle was turbo charged back in the day with a small IHI turbo.
Scoobie Steve is offline   Reply With Quote
Old 06-03-2004, 11:39 PM   #4
thechase
Member#: 61737
2004 WRX STi
a Garrett GT12 is pretty small...the inlet for it is like 1"!!! go to www.turbobygarrett.com and check it out. It may work for what you're wanting to do.
thechase is offline   Reply With Quote
Old 06-04-2004, 07:39 AM   #5
pistoffjstr
Member#: 29283
Red
How did you know
seriously me and a friend of mine built a riding tractor that dose about 30 mph and now we want to try to get really hurt
thanks for all the input ill check out these suggestions and one day post a movie of my crazy tractor
Old 06-04-2004, 11:18 AM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
The KP31 from 3K-Warner (a part of BorgWarner) is pretty small.
It's currently used in the Daimler Chrysler 0.8L Smart diesel in Europe and can spin up to 290,000 RPM. Here's a large cut-away view of the entire turbocharger:
http://www.turbos.bwauto.com/files/p...nger_36_42.jpg
Jon [in CT] is offline   Reply With Quote
Old 06-04-2004, 04:32 PM   #7
pistoffjstr
Member#: 29283
Red
that is one small turbo
Old 06-04-2004, 11:11 PM   #8
Scoobie Steve
Member#: 2289
Originally posted by pistoffjstr
How did you know
Must be something in the air here in Bangor. I try to turbocharge EVERYTHING! Right now every car i have is turboed. I was working on putting a turbo on my snowmobile and dirt bike but lost interest.
Some things to ponder when turboing a lawn mower. You cant just blow through the carb, you will blow the gas right back into the gas tank. You need to mount the carb on the intake of the turbo. Also a lawn mower carb is junk. A small motorcycle carb is much better because you can file the main jet needle to richen the mixture at any throttle position. Most lawn mowers use a fixed magneto for spark(NO ADVANCE). There is alot more power in those motors with a spark advance. Also a turbo needs oil pressure, not too many mowers have a pressurized oil system.
Does your lawn mower run out of power or RPMs?
Old 06-05-2004, 07:38 AM   #9
pistoffjstr
Member#: 29283
Red
good call scoobie steve
you brought up some good points we were basically just looking to put a turbo on it it dosnt necisarily have to do anything just look neat the tractor goes like hell though you should stop by and check it out one day
Old 06-05-2004, 02:21 PM   #10
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
if youre already going to get a new carb, you might look into blow through carbs-i think thats what theyre called. wont mounting the carb before the turbo require you to run really rich.
mr. m is offline   Reply With Quote
Old 06-05-2004, 04:01 PM   #11
Scoobie Steve
Member#: 2289
Using a blow through carb requires a pressurized fuel system and a 1:1 RRFPR to keep fuel pressure above boost level, not the easiest way to turbo a lawn mower
Old 06-06-2004, 03:24 PM   #12
Jon [in CT]
Member#: 2992
02 WRX Sedan
Just to document this in a thread I can find later, it appears the TD02 from MHI was described as the world's smallest turbocharger when it was introduced in the 1983 Mitsubishi Minica. MHI now apparently also makes a TD015 model line, which I suspect is even smaller.
http://www.mhi.co.jp/gsh/epict142.htm
Smallest turbo to get a 2.5 4eat to dip 12's? 03MBP Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 08-29-2008 09:50 PM
what is the smallest turbo there is? dodiox Off-Topic 52 06-29-2006 06:15 AM
what is the smallest turbo they make? pimpomtic General Community 5 09-20-2002 11:14 PM
Arranged my 40 pcs. sockets back in order from the smallest to the largest. Subies General Forum Archive 7 10-11-2000 07:46 PM
smallest diameter rim that will fit over RS brakes? Strepto Technical Forum Archive 10 08-15-2000 08:28 AM
