Old 06-03-2004, 09:36 PM   #1
titanium wrx
Member#: 36977
2002 Wrx
Default Any ideas of what is going on?
I have the cobb stage 2 reflash and just put a vf30 and sti injectors and with the stock turbo i had on it would hit 17.5psi and now I did not push the car too much but now only hits 10psi with the vf30, is there a reason why this is happening?
titanium wrx is offline   Reply With Quote
Old 06-03-2004, 09:46 PM   #2
03WRXMA
Member#: 35081
2012 WRX
Your FBC hose, and/or restrictor isnt on properly, or its borked.
03WRXMA is offline   Reply With Quote
Old 06-03-2004, 09:48 PM   #3
MY04WRX
Member#: 54565
2004 WRX
Java black
seems normal, i have the same setup and everybody i know with stage 2 get around 15 psi.
Also how long have you had stage 2? It takes a couple of days for the ecu to learn.
WILL
MY04WRX is offline   Reply With Quote
Old 06-03-2004, 09:57 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I bet the vac 'T' isn't connected properly on the turbo, or the 'pill' is missing.
Old 06-03-2004, 11:11 PM   #5
titanium wrx
Member#: 36977
2002 Wrx
I just tried a few things first i clamped off the hose going to the solenoid and nothing changed then i undid the hoses to the accuator on the turbo and it hit full boost. So why would that be. Do i need to get a boost controller now that i put a bigger turbo on? Because i thought the computer can do it.
Old 06-03-2004, 11:16 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
You should put the vac hoses off the stock turbo on the VF30....make sure that the hoses go in in the same way...there is a little 'metered orifice' or 'pill' in the one that goes on the turbo nipple. That hose with the 'pill' MUST be in place and in the correct place or, many times, symptoms such as yours result.
Old 06-03-2004, 11:52 PM   #7
titanium wrx
Member#: 36977
2002 Wrx
Thanks I had the vac hose switched around, I redid it and now hit full boost.
Old 06-04-2004, 07:42 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Have fun....boost safe
Old 06-04-2004, 08:07 AM   #9
1DOWNCLOWN
Member#: 50287
02 WRX
no fuel pump???
1DOWNCLOWN is offline   Reply With Quote
I have NO idea what is going on here KingGalantVr4 Off-Topic 30 05-13-2008 08:03 AM
Any idea when JGTC is going to be on Speedchannel? az ej20 fan Motorsports 0 12-09-2004 01:18 AM
Ok. What in the name of poop is going on? STi Sev Bay Area Impreza Club Forum -- BAIC 9 11-22-2002 09:36 PM
('93-'01) Subie of the Week? What is going on? WRX Fan Impreza Forum 6 08-01-2001 01:54 PM
