Old 06-04-2004, 01:11 AM   #1
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
Default Custom TD04 Turbo Kit Price and Parts List
Guys: Please feel free to modify this basic list for a basic turbo kit. Please whoever has done something similar, please reply and lend your tech support/experiences. We need some newcomers!!! I stumbled upon this one a while ago and decided maybe someone would like to see it.
1 Used TD04L-13G from a $150
USDM WRX
bought used at http://i-club.com/forums
2 Earl's -10AN Weld-in Fitting $7.69
Part #EAR-967110
http://www.summitracing.com
3 Russel 45deg. -10AN Hose end $17.95
Part #RUS-610110
4 Russell 3' 10AN Braided Steel hose
Part #RUS-632150 $17.50
5 Bosch 1" outlet BOV $45
http://saabperformanceparts.com
6 370cc Nissan Silvia Injectors $120
(check sr20deforum.com
and freshalloy.com for used sets)
7 USDM WRX Fuel Pump $50
(check nasioc.com/forums or i-club.com)
8 Custom Stainless Steel $175
up-pipe
from Chad Stamper http://uniquemotorsports.com
9 Custom Stainless Steel $240
downpipe
10 Catco Universal Catalytic Converter
Heavy Duty 2.5" inlet/outlet $99
Part #CTO-8006
11 Custom 2.5" downpipe-back exhaust
$450
12 Borla 2.5 catback exhaust
13 MidPipe -- Downpipe to catback exhaust
14 WRX Intercooler $150
Custom charge pipe should be made.
15 bolts for IC/Turbo charge pipe $0.66
6mm-1.0 x 20mm
Home Depot SKU 30699 35788
Autometer Sport-Comp Gauges
17 Fuel Pressure 100PSI $75
Part #3309
18 Boost -30 to 25PSI $50
Part #3301
19 EGT to 1600F $106
with probe included
Part #3365
http://optauto.com
20 Autometer Dual or Triple 2 1/16" A-Pillar Pod
Part #20590 $30
http://nipponpower.com
21 Rumblesoft Carbon Fiber Air Intake and Turbo to Intercooler Pipes:
Part #IHATEKURT $250 ($100 in Carbon Fiber and
http://rumblesoftracing.com hours of pain, suffering
 and epoxy-induced hallucination)
Various Plumbing Stuff:
22 3-2.5" Silicone reducer
http://www.bakerprecision.com $19.99
23 2.5"-2.25" Silicone reducer
http://www.bakerprecision.com $18.99
24 2" Hump Hose x 2 $40
http://www.roadraceengineering.com
25 Brass Tees (Coolant lines) x 2
(Home Depot) $10.43
26 6 ft. 5/8" Heater hose
(Pep Boys) $6.99
27 3 ft. 3/4" Heater hose
(who needs samco BOV
and vacuum hoses!&@)
(Pep Boys) $5.99
28 Home Depot Catch-can $10
JB Weld some PVC drain piping together,
add 1/2 OD fittings and route
the valve cover breathers to it.
29 3" Band Clamp x 4
(Home Depot) $2.96
30 2" Band Clamp x 4
(Home Depot) $2.40
31 1" Band Clamp x 10
(Home Depot) $4.50
32 Bag of Zip ties
(Home Depot) $1.99
Electronics you might want, but don't absolutely need:
33 J&S Ultrasafeguard Ver. II - $495
http://www.jandssafeguard.com
(I'd recommend this if you opt not to use a standalone ECU)
34 Apex'i SAFC - $200
(you can get these used all over the place.
nasioc.com/forums)
35 Some sort of boost controller. - $50-500
36 Greddy E-Manage Fuel and Timing Piggyback computer $450
As far as whats left to finish my kit, I will have to modify the stock wastegate for 5 psi, clock the turbo (td04), fabricate a charge pipe, buy a fuel pump, some type of injectors that will fit my 96 2.2l intake manifold, install my e-manage and my Autometer boost & EGT gauges. Today I just ordered the WRX oil pan and am soon going to order the return and feed lines[] and connections to be welded to the pan.
Changing WasteGate down to 5 PSI
The conection between the wastegate actuator rod and the wastegate is threaded. You have to unclip the actuator rod from the wastegate and turn the end of the rod. Shorter=more longer=less. Then with the boost gauge you can check what it is set at, and it won't go any higher than that.
C H R I S
crk4 is offline   Reply With Quote
Old 06-04-2004, 02:41 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
u got raped on that turbo man
Old 06-04-2004, 02:43 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
also adjusting the arm like that will DESTROY ur spool up time
Old 06-04-2004, 02:50 AM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
do Nissan injectors work on 2000+ fuel rails and are they high impedance? Just curious
benjaminetanyahoo is offline   Reply With Quote
Old 06-04-2004, 03:18 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 06-04-2004, 07:09 AM   #6
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
nice list guys! Keep truckin!
Hitokiri is offline   Reply With Quote
Old 06-04-2004, 11:11 AM   #7
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Good write up, I'll link you guys with my setup and prices when I get some time.
-Jon.
NeaD is offline   Reply With Quote
Old 06-04-2004, 12:15 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
taping the header is EASY i dont know y people freak out about it all u need is a reference chart like 1/4" npt uses a 22/42 <no thats not the size just an ex.> either buy/borrow that bit and tap and it just works itself
dont do it on the car
i dont care how many poeple tell u its ok theyre stupid and metal bits WILL get into everything
Old 06-04-2004, 01:05 PM   #9
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Smile What I have so far...
  • $315 - Greddy E-Manage w/ all harnesses, software support, and usb
  • $120 - TD04 Turbocharger
  • $70 - WRX Intercooler
  • $9 - Charge Pipe
  • $60 - WRX Exhaust Manifold
  • $0 - WRX Up-Pipe
  • $0 - WRX Down-Pipe
  • $0 - WRX Cat
  • $0 - WRX Y-pipe
  • $55 - WRX Waterpump, T-Stat, and housing
  • $20 - WRX Turbo Inlet
  • $40 - WRX Power Steering Pump
  • $19 - Remote PS Reservoir
  • $25 - WRX Fuel Pump
  • $150 - RC 440cc Injectors, clips, and spacers
  • $145 - Greddy bov (Custom adapter)
  • $70 - Stainless Steel Oil-Feed Line
  • $15 - Weld-on Fitting for Oil-Drain Line
  • $150 - Engine Cradle
  • $25 - Poly Steering Rack Bushings
  • $380 - ACT Stage 1 Clutch
  • $53 - Autometer Boost Gauge
  • $180 - Autometer EGT/AF Gauge
  • $0 - Custom Brushed Aluminum Gauge Bezel
  • $200 - Blitz Axle-back and Custom 2.5" Intermediate
  • $25 - 5/16" Fuel Injection Hose
  • $0 - Barb adapter for fuel rails
  • $8 - 3/8", 1/4" heater hose
  • $5 - Vacumm Line
  • $50 - Fuel Injection/Standard Hose Clamps
  • $30 - Kartboy Exhaust Hangers
  • $15 - T's and Barb Fittings
-Brett
ExecNav is offline   Reply With Quote
Old 06-04-2004, 03:21 PM   #10
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Wow, that's my list from 3 years ago, so factor that in to the pricing Also, adjusting the wastegate actuator arm really didn't hurt all that much. Anyway, party on
Darshu is offline   Reply With Quote
Old 06-04-2004, 04:00 PM   #11
crk4
Member#: 43617
1976 Ford Bronco
Hey guys:
The guy from the Subaru dealer parts department told me that I'm making a mistake by thinking that the 2002 WRX oil pan is going to work with my 96 ej22 engine.
WHO HAS USED THE WRX PAN BEFORE ON A BIGGER ENGINE?
He said the WRX pan will NOT bolt up to the 2.5...and also that the STI pan is different.
So who is right? Only real proven answers please.
Have a good weekend,
CHRIS
Old 06-04-2004, 04:08 PM   #12
Darshu
Member#: 1676
98RS w/ EJ257/Dom
The STi oilpan is different in shape, but the flange where it bolts to the block is the same, as far as I know. Anyway, that's not relevant to the question you're asking, which is "will a WRX oilpan bolt to my Phase 1 EJ22 block" and the answer to that is yes.
Old 06-04-2004, 04:09 PM   #13
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Edit: too slow.
-Brett
Old 06-04-2004, 04:58 PM   #14
crk4
Member#: 43617
1976 Ford Bronco
Thanks Darshu thats the answer I was looking for. A few more questions:
How will I be able to supply coolant to the turbo and where on the engine will it come from?
Will Legacy turbo fuel rails/injectors be sufficient for 5 psi on this engine? Any suggestions? The RC Engineering ones look nice but I dont know if they will fit my intake manifold.
Will STI engine mounts stop my car from sort of "bucking"...I dont know how to describe it...when I floor it then if I let off quick its a really quick jerking. What will make this go away?
Scoobaru RS: For what reason did you buy the WRX water pump, thermostat and housing, power steering pump?
Thats it for now,
CHRIS
Old 06-04-2004, 05:32 PM   #15
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I have to use the water pump because the outlet on the stock RS waterpump faces down, which prevents me from using the WRX exhaust manifold (runs to the front rather than straight back like the RS manifold). The outlet on the WRX waterpump is on the front away from the manifold. The thermostat housing has a different bolt up pattern than the RS, so I have to use the housing as well.
As far as the powersteering pump, since I'm using the WRX up/down pipe and turbo, the turbo is positioned so that the inlet is facing under the intake manifold, since that's how the WRX turbo inlet is routed. The RS power steering reservoir and purge control valve is mounted on the front of the manifold. These have to be relocated to accomodate the turbo inlet. I decided to use the WRX pump because it had the lines and everything I needed.
-Brett
Old 06-04-2004, 08:12 PM   #16
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The EJ22T injectors should be fine, yes.
The coolant can be taped from one of the coolant lines. I plan on using the extra pump lines on the WRX water pump though.
CHRIS
Actually some aftermarket differential bushings (Ala whiteline) and a sti tranny mount (which I think your car can use, im not sure) should cure that. Engine mounts dont usually do a whole lot for drivetrain thuds, which I had too just like yours and went with the whiteline diff bushings and a DIY eurathane filled tranny mount which cured them.
Racecomp Engineering updated pricing and parts list-Canada only dalesalignment&brake Suspension/Brakes/Handling 0 12-10-2009 12:43 PM
FS: MA - RS Custom TD04 Turbo kit everything you need but EM Aphex28 Engine/Power/Exhaust 11 09-15-2007 12:03 PM
PRICE DROP!!!!! 1998 Impreza L rs clone TD04 turbo with fmic and many more mods turbo'98L Private Vehicle 'For Sale' Classifieds 9 08-22-2007 08:45 PM
FS: Custom GC turbo kit w/ full exhaust and engine management smahala1286 Private 'For Sale' Classifieds 0 06-15-2006 09:07 PM
RS part out thread.. Koni, Ground control, Turbo kit, element and more jetfan8178 Private 'For Sale' Classifieds 42 01-13-2005 06:19 AM
