Old 06-04-2004, 05:14 AM   #1
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
Default sard radiator on a turboed rs
basically the setup i bought came with an sti resevoir tank
3 barbs on top and 1 on the bottom
now one barb on top is for the turbo coolant return
and the one leading from the cap is the overflow line
NOW THIS IS WHERE I NEED HELP
the last barb on the top feeds to the rad.
and the big one on the bottom is supposed to go to the water pump
but since rs engines pumps arent setup to recieve this line i was told to" T just at the water pump exit"
is this correct?? should i even bother doing this?
cant i just plug the top line and use the bottom one to route straight to my radiator?
im not real familiar with this
but it works out in my head
let em know you thoughts
mike
kaneda3 is offline   Reply With Quote
Old 06-04-2004, 06:10 AM   #2
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
OK, looking at this pic I borrowed from IA Performance, the bottom nipple at 6 o'clock is the coolant return line, the one at the 2 o'clock pos. is the overflow and the one at 3 o'clock is the radiator feed- the one you cannot see is the water pump feed that goes into one of the black coolant crossover lines that go across the top of the block. You could seal off that bottom nipple or re-route it elsewhere if you have another source to supply your water pump- I don't see an issue here provided you have coolant going to all the adequate areas.
MK19_ is offline   Reply With Quote
Old 06-04-2004, 06:25 PM   #3
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
yeah thats just a better description of what i said
thanx
the one to the turbo is going to be blocked(mine is not water cooled)
and instead of running the 3o'clock one to the rad i was just going to use the underneath one for this
is this ok?
am i missing something
i mean there was never one running from this tank(basically because i never had this tank before) to the water pump
so do i need to run one now?
mike
Old 06-06-2004, 02:21 PM   #4
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
noone has done anything like this?
Old 06-08-2004, 11:15 PM   #5
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
please?
Old 06-09-2004, 05:23 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
You could install a wrx water pump and then you'd have that extra inlet. Not sure if you can just t it off though.
Drac9 is offline   Reply With Quote
'05 STi radiator on a '92 Legacy turbo shemoves Subaru Conversions 3 03-05-2009 09:41 AM
Sard Injectors On Perrin Fuel Rail Fit? warui111 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-09-2006 05:54 AM
Best tire Size for 17inch Wheels on a Turbo RS?(Gearing?) yebokmj Brakes, Steering & Suspension 4 06-29-2001 02:55 PM
Peak Boost # on turboed RS? Minnesota WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-13-2001 06:20 AM
question on emissions with turboed RS huey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-19-2001 05:57 AM
