Old 06-04-2004, 08:46 AM   #1
kitbar
Member#: 41411
2004 WRX Sedan
Java Black No Spoiler!
Default help: sub doesn't make any bass
Perhaps someone can help me diagnose the problem?
I can hear my sub playing music but it doesn't make any bass.
I've tried:
1) the fuse is not blown
2) the amp is receiving power
3) swapped to another amp and no bass still
My setup is stock HU to Line out convertor to amp to sub.
I am guessing either
1) sub is broken
2) line out convertor is broken
what do you guys think?
thanks!
kitbar is offline   Reply With Quote
Old 06-04-2004, 09:17 AM   #2
02SilvaWagon
Member#: 33933
2011 WRX Limited
What is the crossover on the amp set to?
Also, try unplugging one RCA from the amp and see if the bass improves. If you wired one channel of the line out converter backwards you will get cancellation and won't get much sound.
02SilvaWagon is offline   Reply With Quote
Old 06-04-2004, 09:22 AM   #3
kitbar
Member#: 41411
2004 WRX Sedan
oh i forgot to mention, it was working fine, then yesterday it just stopped making bass
Old 06-04-2004, 11:21 AM   #4
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Well, that is definately more helpful info for troubleshooting. Can you say what kind of amp it is (specific model), what kind of sub it is (specific model) and how everything is wired up?
I would be quick to guess your sub is blown. If anyone else has a sub with the correct ohm setup to test that theory with; or vice versa, if you can stick your sub on someone else's amp...
offset
offset is offline   Reply With Quote
Old 06-04-2004, 02:20 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The protect light on the amp isn't on is it?
Have you checked the wiring on the sub itself? Maybe the wire fell out of one of the terminals
Old 06-04-2004, 06:46 PM   #6
kitbar
Member#: 41411
2004 WRX Sedan
Sorry i am very new to audio so I don't know the brands, i got them used. Okay i will check and see if the amp has a protect light. I assumed the light = power on.
if one of the wires fell out would the amp still play music? cuz mine plays music but makes no bass
Old 06-04-2004, 06:51 PM   #7
Member#: 51961
2005 STi
2012 WRX
I didn't even catch the part about it playing music....
Sounds like you have a highpass filter on. Have you checked the amp's built in filters (if it has any) to make sure it's not set to HP or HPF?
Old 06-04-2004, 07:08 PM   #8
kitbar
Member#: 41411
2004 WRX Sedan
perhaps it is my line out convertor that is malfunctioning then. i'll take the dash apart and check that thing out again.
Old 07-07-2004, 03:17 PM   #9
kitbar
Member#: 41411
2004 WRX Sedan
update guys, it was the sub, it was broken. replace with a momo
Installed Pioneer Avic Z3 in my '08, now factory sub doesn't work.. p2adan Car Audio, Video & Security 2 04-02-2010 05:13 PM
This doesn't make any sense!! A7X Car Audio, Video & Security 15 02-23-2007 10:28 PM
Help: Hood doesn't close viodea Service & Maintenance 5 07-26-2003 10:12 AM
Need help: car barely makes any boost atf78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-02-2002 05:57 PM
8 inch sub in truck???Enough bass?? GM991 Car Audio, Video & Security 10 02-23-2002 01:27 PM
