05-30-2000, 10:36 AM | #1 |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Fuel Settings
I was just searching for an old post about fuel settings and could not find it here or in the General Forum.
Could all of those with power adders (Turbo,Supercharger,NOS) please post your fuel settings here for reference purposes? If you cannot post in rpm increments, can you please state what your fuel pressure regulator/riser is set at? I hope this post could be used as a reference point for current and future 'power-adder' owners as a baseline for their tuning purposes. Thanks! And thanks AdamRS, Richard Squire and everyone else for your past post on your settings. It helped out alot! I use a Hyper SFC fuel controller with a Stage I turbokit. My settings are:
Running a 60 shot NOS, the settings are:
1997 2.2ltr Subaru Impreza Outback Sport Wagon BTW: EGT stays in the 1100-1200 range. EGT probe is in the same location as SteveS setup. See his website for exact location. [This message has been edited by Kevin Thomas (edited May 30, 2000).]
05-30-2000, 03:39 PM | #2 |
Member#: 6
Vehicle:2013 BMW M3 Coupe Interlagos Blue |
Kevin ~~ You know most of my particulars. Just to make this clear I am using the Apex'i S-AFC and not the Field SFC.
EDIT: I think I managed to screw this thread up royally by trying to post my settings in a table. Kevin, check out the journal page on my site for my current settings.......... [This message has been edited by SteveS (edited May 30, 2000).] |
05-30-2000, 03:54 PM | #3 |
Member#: 216
Kevin,
I have a MY99 2.5 RS that has been fitted with a IHI turbo off an old Legacy. No intercooler running 5.5 psi. Fuel pressure at idle is 50 psi + 1 for each pound of boost. My S-AFC is set at: 3000 - 5 4000 - 8 5000 - 10 5500 - 12 6000 - 15 6500 - 15 My o2 voltage stays between .835 - .865 at all times (at WOT). Forgot to say that those are all HI throttle settings, no correction for LO throttle. I set LO throttle as 7% and HI as 30%. [This message has been edited by Tim Prudence (edited May 30, 2000).] |
05-30-2000, 07:46 PM | #4 |
Member#: 501
International
Vehicle:1998 2.? RS Turbo ;) RBP |
What kind of EGT's do you guys commonly see with your settings as well as how close to the cyl. do you have your probes?
Thanks guys, Andre PS I will post mine as soon as I have all the "tuning" done. |
FS : 2003 WRX Fuel Rails and OEM TMIC!!! | wrxSLEEPER03 | Engine/Power/Exhaust | 28 | 06-15-2010 01:29 AM |
Parallel Fuel set up | kakarotoni | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-09-2008 07:56 AM |
FS: (NJ) STI Fuel Set Up | cpunlamd | Engine/Power/Exhaust | 13 | 05-23-2008 07:18 PM |
Dual walbro fuel set-up- 800whp capable | Peeblesmx445 | Engine/Power/Exhaust | 2 | 11-21-2007 12:33 PM |
Looking for Fuel setting using Silva injectors on a 2.5 | yebokmj | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 07-31-2003 06:38 PM |
