Old 06-04-2004, 06:54 PM   #1
codyek
Member#: 60558
2003 2.5 rs
midnight blue
Unhappy white smoke
ok just installed a ludespeed kit on my 03 rs. with a voltage clamp and a timing map contr. took it for 3 test drives to see if it had detonation , rrfpr was maxed, and it did. i never reved over 4500 k the nex thing i noticed was major white smoke out the exhaust, does anyone know what i screwd up. and takes for ever to start help please
codyek is offline   Reply With Quote
Old 06-04-2004, 11:43 PM   #2
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
POP!
Seriously... check your compression. It may also be a problem with the turbo leaking oil, among other things.
-Charlie
phattyduck is offline   Reply With Quote
Old 06-05-2004, 01:43 PM   #3
codyek
Member#: 60558
2003 2.5 rs
midnight blue
after inspecting it im pretty sure im burning oil checked the oil return an its not doing it as bad, thanks
Old 06-05-2004, 02:22 PM   #4
Unsung Boxer
Member#: 37196
white smoke is a sign of coolant in the combustino chamber. Either it is entering thru the turbo block itself (if its watercooled) or thru the headgaskets.
RS headgaskets are not known to hold much boost. Darshu blew his at about 4psi.
I recommend bringing it to a shop, and have them use an Exhaust gas analyzer to sniff the radiator for combustion gases. If there is any hydro carbons in the coolant, it is 95% chance that the headgasket is blown.
If you choose to get the heads re-sealed, look into getting them o-ringed. It costs between 90 and 125 bucks.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-05-2004, 02:34 PM   #5
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Black smoke = running rich
white smoke- coolant
blue smoke= oil
The smoke might look white from inside the car in the rearview when it is in fact blue. Better to have someone follow youand tell you what color it is.
Drac9 is offline   Reply With Quote
Old 06-05-2004, 05:55 PM   #6
codyek
Member#: 60558
2003 2.5 rs
midnight blue
pretty sure its blue, ill look into it more, thanks a million
Old 06-07-2004, 08:32 PM   #7
Unsung Boxer
Member#: 37196
blue smoke= oil
Drac is right on the colors.
-Jake
Old 06-07-2004, 10:59 PM   #8
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Try popping the radiator cap off when the car is at idle, have someone rev the motor up and look at the coolant in the radiator, sometimes you will be able to see small bubbles in the coolant... somewhat hard to see... and it doesn't always work... but worth a shot to try and isolate whether it's a head gasket or bad turbo seal. Also check your intake tract right after the turbo for any condensation or oil.
no-coast-punk is offline   Reply With Quote
Old 06-07-2004, 11:18 PM   #9
Akarui
Member#: 60195
World Rally Blue
make sure you do what No-Coast said from a cold start or you will be a very burned person....
Akarui is offline   Reply With Quote
Old 06-08-2004, 12:39 AM   #10
codyek
Member#: 60558
2003 2.5 rs
midnight blue
thanks guys, after i checked the oil return havent seen that much smoke, think it was clogged
White Smoke, or Steam??? BlueDemon South East Region Forum 6 06-03-2002 04:43 PM
White smoke from the catch can IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-20-2002 03:19 AM
white smoke from the exhaust IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 11 09-11-2001 02:38 AM
white smoke coming out from the exhaust!!!!! Hojai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-15-2001 04:03 PM
White Smoke? AudioFan Technical Forum Archive 15 07-21-2000 09:14 AM
