Old 06-05-2004, 08:50 AM   #1
2002ImprezaRS
Member#: 58211
2002 Impreza
Default Turbo on a 2002 RS
2002ImprezaRS is offline   Reply With Quote
Old 06-05-2004, 01:56 PM   #2
codyek
Member#: 60558
2003 2.5 rs
midnight blue
i have an older ludespeed kit off a 99' rs put it in my 03' it fit, jus the cross member a lil shorter, if that helped,
codyek is offline   Reply With Quote
Old 06-05-2004, 04:31 PM   #3
Aphex
Member#: 146
'16 WRX Limited
but between AT and 5mt, the bracket that holds the turbo to the transmission will not fit right.
Aphex is offline   Reply With Quote
Old 06-07-2004, 06:31 PM   #4
2002ImprezaRS
Member#: 58211
2002 Impreza
ok thanks for the info so with a lil modding to it i can get it to work can someone give me a ruff est on HP? or tell me if you have it on your car and are satisfied with it
Old 06-07-2004, 08:02 PM   #5
codyek
Member#: 60558
2003 2.5 rs
midnight blue
you should only be boosting 3-4 psi max, with an i.c. should be around 60 hp. im run'n 4 psi w/o an i.c. an not tuned yet and its a lot faster
Turbo Kit For 2002 RS 2002ImprezaRS Private 'Wanted' Classifieds 0 06-05-2004 09:17 AM
2001 RS exhaust on a 2002 RS ques. DDMan Normally Aspirated Powertrain 10 04-07-2002 05:43 PM
Small Turbo on a 2002 2.5RS..turbo newbie.. DeusExMachina Normally Aspirated with bolt-on Forced Induction Powertrain 5 03-14-2002 04:46 PM
WIll a GC8 turbo kit fit on a 2002 RS? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 8 12-14-2001 09:53 PM
anyone make a turbo kit for 2002 rs? onesillyracer Normally Aspirated with bolt-on Forced Induction Powertrain 9 10-13-2001 03:12 PM
