Old 06-05-2004, 09:10 AM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Default head gasget thickness
what is the thickness of the head gasget for 99RS SOHC? 1mm or 2mm
ChAi is offline   Reply With Quote
Old 06-05-2004, 10:42 AM   #2
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
i suggest you find one and measure it to be sure.
but thhis is what i found through some research.
99 ej25 HG is .058cm
this was from:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
greg donovan is offline   Reply With Quote
Old 06-05-2004, 12:31 PM   #3
John*G
Member#: 19562
95 coupe
red
This doesn't really answer your question but they are making me one that is 0.027 http://www.cometic.com/
John*G is offline   Reply With Quote
Old 06-05-2004, 01:06 PM   #4
greg donovan
Member#: 60743
'95 Impreza L
thats cm i hope
Old 06-05-2004, 03:16 PM   #5
ChAi
Member#: 1277
1999 Minnam Stage 2
thank for the info
so if i have turbo in my car, can i use the 98 ej25 DOHC head gasket (0.152cm) on 99 EJ25 SOHC to lower the compression ratio?
and what is the STI 2.5L head gasket thickness
Old 06-05-2004, 06:55 PM   #6
greg donovan
Member#: 60743
'95 Impreza L
Originally posted by ChAi
thank for the info
yes you can use the dohc gasket on a sohc car. you may have to modify the gasket to make sure the oil and wat er passage hole line up. you dealership should have both in stock so you can compare. and yes it will lower the CR. about 1 point.
Old 06-05-2004, 10:02 PM   #7
ChAi
Member#: 1277
1999 Minnam Stage 2
what do you mean by "1 point" is it from 8.5:1 to 7.5:1
Old 06-05-2004, 11:02 PM   #8
greg donovan
Member#: 60743
'95 Impreza L
yes 10.1:1 to 9.1:1 would be a change of 1 point from what i understand. those numbers are just for illustration purposes.
use this page to calculate CR:
http://www.kb-silvolite.com/calc.php...1441a39409fc71
Old 06-06-2004, 12:05 AM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
how do you make the intake manifold hook up right if you change the distance from head to head?
RS_to_WRX_swap is offline   Reply With Quote
Old 06-06-2004, 12:22 AM   #10
greg donovan
Member#: 60743
'95 Impreza L
forgot about that. im not sure. maybe there is enough room to make it fit? like i said not sure.
Old 06-06-2004, 03:01 AM   #11
ChAi
Member#: 1277
1999 Minnam Stage 2
it only 2mm different not that much
Old 06-08-2004, 03:01 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
FWIW...I have a new set of Cometic gaskets that I will sell if anyone is interested. P/N C4264HP, Thickness is .043" with a compressed thickness of .040". I will let them go for $110shipped.
Reason for selling? They're making me a set of .027" gaskets to run around on......
If you're going turbo, they'll make you a set of .060" gaskets or even thicker if you want. Call Kevyn at 440-354-0777ext.120 and tell him Jay from Sourcemotorsports sent you!
Jay Storm
Jay Storm
Old 03-09-2005, 06:06 PM   #13
Lavery
Member#: 77896
98 impreza 2.5rs
back from the dead...
Jay, did they make these specially for you. how much? and what are they made of? thanks
Lavery is offline   Reply With Quote
Old 03-09-2005, 08:54 PM   #14
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
I have a .027" cometic HG for sale too. its brand new.. $100 bucks shipped and its yours.
Crash477 is offline   Reply With Quote
Old 03-09-2005, 09:09 PM   #15
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
tempting...
Old 03-09-2005, 09:14 PM   #16
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
its still in its original wraping, never opened.
Old 03-09-2005, 11:52 PM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
They were special order at one time, but they have a stock number now even though it's not listed in their catalog.
The construction is 3 layers of full stainless steel. The outer surfaces are evenly coated with a nitrile coating as opposed to OEM gaskets only having beads run around the key areas and a layer of aluminum or some other soft material.
Buy Crash477's set. He got them from me and now doesn't need them. Help a brotha out!!!! You won't be disappointed.
As for manifold fitment with the thinner gaskets, it's a non-issue. There is more than enough room to fit the intake. If you've portmatched, it may require a little massaging to get the flush finish back. It may make the exhaust manifold a little more tricky to slide over the studs. A little more arm power is all that's needed to gently squeeze the header in while lifting it into place. Although, this allows the header to stay put when the nuts are loosened instead of falling on your head.....
Jay Storm
Old 03-10-2005, 01:21 AM   #18
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Everywhere I've ever seen "1 point" used, it refers to 0.1, -> "point 1"
AKA 10.1 to 10.0
Not even talking about the gaskets here, just the wording. I have no idea how much the compression would change with the other gaskets, but a whole 1.0 drop seems like a LOT from just thicker gaskets...
jasona is offline   Reply With Quote
Old 03-12-2005, 07:37 PM   #19
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Originally Posted by RS_to_WRX_swap
tempting...
still thinking about it?
Old 03-12-2005, 07:48 PM   #20
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
yeah, it would help to know what the compression will be after the head gasket swap however.
Old 03-12-2005, 09:31 PM   #21
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
so this would go on the 03 RS right? so it would be about 10.5:1 instead of 10:1
Old 03-13-2005, 12:07 PM   #22
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
yeah, ok thats what i thought...
Old 04-08-2005, 04:28 AM   #23
QksilverRS
Member#: 16826
01 STi DOMINATOR 3
444 WHP 431 WTQ
Jay Storm
Jay Storm
HOW MUCH DOES THIS AFFECT THE COMPRESSION RATIO? ANY NOTICABLE GAINS OVER THE STOCK GASKET SIZE?
QksilverRS is offline   Reply With Quote
Old 04-08-2005, 08:19 AM   #24
Storm
Member#: 5218
96L Most Over-
Developed Beater
No need to yell.....You ever hear of the PM function??? I have 3 different thicknesses listed in that one post....which one are you talking about?
With the thinner ones, I think there are noticable gains over the stock thickness....but I don't have any dyno numbers. Many others have used these thinner gaskets.... maybe one of them will have concrete numbers. Cometic can tell you how much it will change, but I think the figure is about .3-.5....maybe a little more....
If you need a set, lemme know....I have one set of .027" left. Check with Crash477 first though, he wasn't going to need his anymore.
Jay Storm
Old 04-08-2005, 01:28 PM   #25
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default I am interested.
Is 027" the thinnest head gasket available for the SOHC EJ25? I remember reading somewhere that the STI gaskets were even thinner.
Also, any issues with piston / valve interference using these thinner head gaskets with stage 2 cams?
powerlabs is offline   Reply With Quote
Head gasket thickness - Is thicker/thinner more likely to leak? bugeyes Built Motor Discussion 3 07-31-2006 02:00 PM
Someone confirm thickness of subaru head gasgets - 0.8mm ?? bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-28-2005 10:18 PM
Ver 7 Head Gasket thickness DuoMaxwell Subaru Conversions 4 09-15-2004 06:55 AM
Head gasket thickness! 2mm? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-18-2003 12:21 PM
Thinner head gasget, bigger compression ratio? tonytiger Normally Aspirated Powertrain 10 05-17-2002 02:53 PM
