Old 04-08-2005, 03:25 PM   #26
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Default Some data
Pulled this out from an old post:
The phase one head gaskets are .060" thick, with the phase two at .020".
The cometic are .040" or .051", using either of these will raise your compression, change your cam timing and possibly result in a piston to head collision.
Be carefull, everything comes at a cost
Quirt Crawford
www.crawfordperformance.com
Is it true? That would mean that using cometic gaskets on a phase 2 block would actually lower its compression.
I think Matt Monson also said that you can't use thinner head gaskets on ph1 blocks because the piston clears the deck on those.
powerlabs is offline   Reply With Quote
Head gasket thickness - Is thicker/thinner more likely to leak? bugeyes Built Motor Discussion 3 07-31-2006 02:00 PM
Someone confirm thickness of subaru head gasgets - 0.8mm ?? bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-28-2005 10:18 PM
Ver 7 Head Gasket thickness DuoMaxwell Subaru Conversions 4 09-15-2004 06:55 AM
Head gasket thickness! 2mm? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-18-2003 12:21 PM
Thinner head gasget, bigger compression ratio? tonytiger Normally Aspirated Powertrain 10 05-17-2002 02:53 PM
