Old 06-05-2004, 11:58 PM   #1
jmj1112
Member#: 57051
02 WRX
Default STI Ver8 cluster in my 02 WRX
Like the title says....Little help needed if somebody has done this already!!!!
Hooked it up and now I have some problems..
First, some how it has effected the radio unit...It blew the fuse after I first installed it....replaced the fuse....blew it again.
Second, the lights in the dash do not dim...not sure if this is correct the other items dim like the boost gauge.
The next couple of things are no big deal...would like to disconect the DCCD light and the Rear dif temp lights.
I'm sure I am not the first to do this conversion and that this probably happed to them.
I did a search but did not find anything.
Thanks for any help!!!!!
Jay
jmj1112 is offline   Reply With Quote
Old 06-06-2004, 02:33 AM   #2
unloadmydodads
Member#: 34615
2003 Subaru WRX
I just put my ver.8 cluster in this past week. The reason you are blowing the fuse in the radio is because you did't cut the b28 wire. The wire you need to cut is on the middle harness(the big one in the middle), it is the yellow wire with the green tracer. I would highly recommend doing another search just to make sure this is the right wire. Try searching "sti gauge cluster" look for the post with about 19 pages to it and start reading. The lights on the gauge cluster do dim. First you have to turn the right knob to you get to the "ILL5" lcd menu on the right. You then have to turn the left knob to the left to dim the cluster. I know in the 19 page thread they tell you which wires to cut to disable the DCCD and Rear Diff lights, but I didn't do this. Just make sure you find the thread first. Good luck and if you have anymore questions shoot me a pm.
unloadmydodads is offline   Reply With Quote
Old 06-07-2004, 12:53 AM   #3
jmj1112
Member#: 57051
02 WRX
Perfect......that is a long thread.....needed to read more into it before I started....
Jay
http://forums.nasioc.com/forums/show...i&pagenumber=1
Old 06-12-2004, 09:44 PM   #4
ljaviation
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
That was a good thread.. and don't forget to wire up that OAT
ljaviation is offline   Reply With Quote
04 Sti Gauge Cluster In My 02 Wrx HOOGUNZO Subaru Conversions 2 07-16-2008 04:32 AM
06 sti gauge cluster in an 02 wrx lovemyrex Electrical & Lighting 2 10-18-2007 11:32 PM
sti gauge cluster in an 02 wrx? michaelpatrick Electrical & Lighting 0 05-10-2006 12:35 PM
USDM STi ver8 cluster in a 2003 WRX? HOPPFL Electrical & Lighting 3 07-14-2004 08:28 AM
STI Vers8 cluster in a 02 WRX jmj1112 Subaru Conversions 1 06-07-2004 12:54 AM
