Old 06-05-2004, 09:12 PM   #1
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Default Turbo Is finally in...Startup is days away
Finally got the turbo in...Should able to finish up the car and start it by m,onday. Then the 3 days of straight driving to get the break in done will commense...I cant wait.
jetfan8178 is offline   Reply With Quote
Old 06-05-2004, 10:09 PM   #2
cronic
Member#: 9749
What turbo is that?
cronic is offline   Reply With Quote
Old 06-06-2004, 01:06 AM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
wow!
way to go!
I'll be doing my install the weeking pretty soon too!!!!!
horray for more rst's!!!
Todd
Hitokiri is offline   Reply With Quote
Old 06-06-2004, 02:17 AM   #4
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
no intercooler?
NeaD is offline   Reply With Quote
Old 06-06-2004, 07:23 PM   #5
Charge
Member#: 3313
Originally posted by NeaD
no intercooler?
I'm thinking front mount.
Charge is offline   Reply With Quote
Old 06-06-2004, 07:26 PM   #6
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Gotta make all the piping. I'm going custom front mount, but I may run stage 1 style till I have time to get the piping made.
Old 06-06-2004, 09:08 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Old 06-07-2004, 01:10 AM   #8
Member#: 47261
I'm thinking of doing something similar to your setup there...
quick questions...
did you move the MAF?
If not, how is that going to work?
How does the MAF hold up in a turbo application?
I haven't researched that last question, but since you are doing up a MAF car I figured I'd ask you.
DAMN THE NON-MAF PEOPLE!!!!
soccer_freak_m@hotma is offline   Reply With Quote
Old 06-07-2004, 01:56 AM   #9
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
I take offense to that in every way!!!!
JK, what turbo is that by the way? Are you going to use a tube and fin intercooler or bar and plate? How much psi (I just ask and wonder if a front mount would be worth it).
impr25rs is offline   Reply With Quote
Old 06-07-2004, 08:12 AM   #10
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Don't look down of the fact that you are MAF based! There is a reason behind all subaru's factory turbo cars being MAF based. If anything you should think of it as extremely positive that you are MAF based.
Todd
Old 06-07-2004, 09:03 AM   #11
Member#: 47261
Todd
extremely positive? How so? I am always under the impression that MAP is easier to work with.
Old 06-07-2004, 10:39 AM   #12
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
White 2.5rs : If need be I can start the car and drive it without a intercooler.
I will still be using the MAF, but most liklly be switching to a 3" GM mAF down the road when i start running more boost. My FMIC is Tube and fin, But is different then anything you've ever seen before.
Old 06-08-2004, 01:59 AM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
it is when you uses a 3.5 bar or 5 bar map sensor.... not when you use the stock "I hate positive manifold pressure" sensor.
Nino should be fine with the stock maf for a little while. but looking at the size of that turbo it looks like you could easily peg the voltage on it pretty quickly once you crank up the boost.
Brad
STiTuner is offline   Reply With Quote
Old 06-08-2004, 03:41 PM   #14
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Yeah, Im sure I won't make it far on the stock MAF...I have some interesting ideas though.I was surprised to find out what other cars use the same basic sensor as the 99 RS...I am ionvestigating the upgrade possibility of those and will let everyone know what I learn.
Old 06-09-2004, 10:51 PM   #15
Unsung Boxer
Member#: 37196
Benefits of MAP: Not bulky
Downside of MAP: if ECU sees more than 1atm, it throws CEL
Fix: Use boost nanny or check valve.
Benefits of MAF: As airflow increases, the MAF will add fuel. For light boost applications, the MAF will add fuel as the Turbo creates boost (still need boost nanny for EGR based MAP)
Downside of MAF: Bulky. Still throws CEL if Air flow exceeds 100%, but more forgiving than MAP
Fix: Voltage clamp at about 4.7volts and Boost nanny the EGR MAP to keep from throwing CEL.
Either way, ur screwed. The sensor is not the problem, its the Naturally aspirated ECU that wasnt designed to see boost.
This can only be corrected w/ Piggy back or Standalone.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-10-2004, 12:54 AM   #16
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Thats why I bought the Hydra
05 tranny is finally in my 02 wagon, but first gear is weird... dwike Transmission (AT/MT) & Driveline 0 03-30-2008 09:21 PM
Wideband is finally in!!!!! need help GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-16-2005 06:45 PM
The Koni/GC combo is *finally* in... (long, pics and story) Patrick Olsen Legacy Forum 29 07-30-2004 12:40 PM
My Protorque TC is finally in! o2sys Transmission (AT/MT) & Driveline 18 05-24-2004 11:51 AM
Car is finally in the paper garmin Alaskan Impreza Club Forum -- AKIC 4 03-01-2004 06:43 PM
