Old 06-06-2004, 11:17 AM   #1
bcristea
Member#: 11343
2008 STi
Default Help!! Car Overheating after turbo install!
Hi,
I hope sombody can help,
I just reinstalled my turbo after porting and not the car overheats and the heat will come out of the vents only ambient air?
I filled it back up with coolant (lost about 1/2 gal after pulling turbo) but it didn't look like it took any?
There are no leaks to be seen?
Any help would be appreciated!!
Brian
bcristea is offline   Reply With Quote
Old 06-06-2004, 12:27 PM   #2
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
did you mix water with the coolant? atleast 50/50?
el~sharko is offline   Reply With Quote
Old 06-06-2004, 12:49 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
burp your cooling system.... You must have an air bubble in it...
jigga is offline   Reply With Quote
Old 06-06-2004, 12:56 PM   #4
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Bleed the system and check the thermostat.
Evil STI is offline   Reply With Quote
Old 06-06-2004, 01:13 PM   #5
ksikyat2000
Member#: 50539
what the two people above said. probably have an air pocket in the system.
ksikyat2000 is offline   Reply With Quote
Old 06-06-2004, 01:33 PM   #6
bcristea
Member#: 11343
2008 STi
Thanks all,
I think its the air bubble thing,
I'm letting it run and the fans came on and some bubbles are coming up in the fill tank.
Does this sound right?
Ill let you know what happens,
PS, Do I need to mix the coolant 50/50?
Brian
Old 06-06-2004, 01:41 PM   #7
ksikyat2000
Member#: 50539
yeah you def need to mix some coolant. even some people suggest a 60 water 40 coolant part mixure.
Old 06-06-2004, 01:55 PM   #8
RightyTighty
Member#: 54993
Stupid question, but:
Are you filling the radiator or the coolant reservoir?
Filling the coolant reservoir just makes it worse!
Open the bleed valve on the left hand side and then fill the radiator through the radiator cap. Run the engine for several seconds rev it a bit and fill the radiator one more time (the engine sometimes holds air pockets).
Also make sure your coolant reservoir is closer to empty than full. Closer to empty will allow any future air bubbles to escape faster because there isn't as much pressure holding it back. A full reservoir puts too much pressure on the radiator and won't let those small air bubbles get out in time. I see a lot of people with too much reservoir coolant. Keep it low and check it weekly to keep it above the low mark.
RightyTighty is offline   Reply With Quote
Old 06-06-2004, 02:52 PM   #9
Opal
Member#: 42091
2004 STi
Righty, great post. I learned a little something. Thanks!
Opal
Opal is offline   Reply With Quote
Old 06-07-2004, 11:31 AM   #10
lobelsteve
Member#: 31992
2007 STI
UGM
Just the had the same problem after putting on my turbo.
Fun to watch the temp gauge shoot up to just below the H.
I was only 1/2 mile from home testing it out. Popped off the radiator cap, overflow cap, and coolant tank cap (in front of turbo) and when the thermostat kicked on it bubbled a bit and then I filled it up with 50/50 and some Redline wetter.
lobelsteve is offline   Reply With Quote
Old 06-07-2004, 01:04 PM   #11
bcristea
Member#: 11343
2008 STi
I got the system burped by filling the overflow tank and not the radiator?
Seemed to work fine, it may have been quicker by filling the radiator but it works now.
Thanks again,
Brian
Overheating after turbo install Mekks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-14-2009 09:00 AM
wtf car overheating after header install...help plz SubieFan98 Normally Aspirated Powertrain 25 07-17-2008 06:09 PM
HELP car overheating after VF39 install A7X Newbies & FAQs 13 07-05-2008 08:22 AM
Car overheated after Accessport install.... -Kevlar- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-21-2006 09:45 AM
Overheating after turbo install sKOOTeR WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-13-2005 02:46 PM
