Old 06-07-2004, 10:02 AM   #1
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Default Map for link+ and ludespeed kit
Guys,
I am buying a link for my ludespeed set up. I think ludespeed set up came with 550 cc injectors and i am running WRX's 420 also I am running 8.5:1 compressiop. With that said can some one help me with a base map.
Can some one expalin to me how to use a wide band o2 with the link or does the link use the stock o2 to record lamba numbers? Is the oem o2 reliable meter to tune the car?
My goal with all these to have a good base map and that will run good with a little tuning of the fuel delivery.
Elliot
Elliot is offline   Reply With Quote
Old 06-07-2004, 10:13 AM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
The LINK+ cannot read WBO2. Yes, it'll work with the stock rear o2 sensor, which should be placed right after the turbo, where the stock FRONT o2 sensor sits........then just get rid of your front o2 which is useless once you have the LINK installed.
I'm sure there is more info under the Engine Management forum, and you might also want to check www.wrxhackers.com 's forums for tons of info on this as well.
-Vic
Wedge is offline   Reply With Quote
Old 06-07-2004, 10:52 AM   #3
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
any info regarding the maps!!
Old 06-07-2004, 11:12 AM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Check the site I mentioned, under Downloads, they have maps there.
Old 06-07-2004, 02:36 PM   #5
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Wedge , can I use your map? what injectors are you using?
Old 06-07-2004, 02:40 PM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
from what I hear with the Link Plus using somebody else's map isn't a great idea because each engine and variables are way different even though they seem the same on paper. For instance
Wedge has a super ej22t SOHC hybrid
You on the other hand has a 2002 RS ej25 NA block with a turbo. You definately would have to add more fuel and what not to the map, and change a lot of settings that is why it's not really worth using his map persay.
Last thing you want to do is load his map, do data logging for one run and kaboom which is very possible.
I would go to wrxhackers.com and check the maps out they have there or find somebody with a very very similiar and go from there. Good luck none the less
Benny
benjaminetanyahoo is offline   Reply With Quote
Old 06-07-2004, 02:56 PM   #7
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
As Benny stated, my MAP was tuned for 750cc injectors (you can find it on my website link down below). But I do have one for an RS-T with 550cc on the Ludespeed kit, it's not perfectly tuned, but it'll idle, run fine, and with good power, just super rich.
Lemme know if you want it, and what email to send it to.
-Vic
Base maps for Perrin GT30 Turbo kit?? Nornesn UTEC 3 11-29-2006 12:39 PM
Need a map for a 35r rotated kit on STi 03twrx UTEC 2 10-27-2006 07:18 PM
LF: Maps for Link Cstmboxermotorsports Engine Management & Tuning 0 01-23-2006 07:51 AM
Map for Link ECU for 2.5 Engine? Maecky Engine Management & Tuning 1 02-11-2005 05:39 PM
Anyone have a LINK Map for 550cc and Walbro Pump NA cpu77 Engine Management & Tuning 1 11-26-2002 06:26 PM
