Old 06-08-2004, 04:36 AM   #1
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
Default My Car is Dying
ok, i think the 10:1 cr on my bone stock motor and the extra 10psi finally caught up with me. i have a rough idle and its misfiring. no smoke or aything like that. no oil in coolant and no coolant in the oil. also when i go to start it sometimes the first turn over it makes a puff/pop noise then wont start, when i trying turning the key again it takes about 3-4 seconds to start. i'm more concerned about the misfire. i have a feeling the lack of a better fuel pump and a afpr isnt helping either.
Setup:
Eaton M-62 S-Trim
J&S Safegaurd
EIC Secondary Injector Controller
2 extra 480cc injectors
NGK Iridium sparkplug 2 steps colder than stock(8 heat range)
any thoughts? - IC
IdenityCrisis is offline   Reply With Quote
Old 06-08-2004, 04:59 AM   #2
kaos200
Member#: 2692
check your compression, I know its probably hard with the SC is the way, but its a good start...
kaos200 is offline   Reply With Quote
Old 06-08-2004, 06:01 AM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Also check your spark plugs.
Drac9 is offline   Reply With Quote
Old 06-08-2004, 09:55 AM   #4
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
i regapped my plugs to .03, they werent off by much. compression is my next test. thanks for the input. - IC
Old 06-13-2004, 04:17 PM   #5
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
I had the same problem, running the same psi of boost... not to burst your bubble, but I bet you a million dollars that your number 4 piston is toats. This accounts for the smoke, the misfiring, and rough idle... If you do a leak down... I bet #4 is toast.. sorry for the bad news, but that is EXACTLY what my motor did.. Do you have a flashing CEL? This is bad.. time to get an sti block assy.
Pi7467mp is offline   Reply With Quote
Old 06-13-2004, 04:17 PM   #6
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
My car is dying :tear: adj789 General Community 25 01-20-2010 08:26 PM
Help my car is dieing!!!!!!!! bxracer69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-15-2005 10:06 PM
my car is dying too soon... WS6toWRX General Community 6 12-23-2002 06:26 AM
My car is dying, help!! Sobelizard109 New England Impreza Club Forum -- NESIC 6 12-08-2002 09:52 PM
EMERGANCY: My car is dying... Kostamojen General Forum Archive 11 12-12-2000 02:47 AM
