Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 06-08-2004, 04:07 PM   #1
Member#: 47261
Default fuel pump fuse
I hope this isn't cross-posting or whatever... but no one answered me in the other thread
Where is the fuse to the fuel pump?
soccer_freak_m@hotma is offline   Reply With Quote
Old 06-09-2004, 03:12 AM   #2
damianq
Member#: 5380
1999 Impreza
Primer
Engine bay me thinks?
damianq is offline   Reply With Quote
Old 06-09-2004, 08:05 AM   #3
Member#: 47261
nah... people did reply to my other post and it's fuse #11...
apparently I can also let the car sit for an hour or so and the pressure should have dissipated
Old 06-10-2004, 10:05 AM   #4
damianq
Member#: 5380
1999 Impreza
Primer
Easiest way is to open the gas tank cap, loosen the clamp around the line & pull the line off the filter w/ a rag around it. Thank way any pressurized fuel gets caught by the rag, instead of spraying all over the engine bay & yourself.
Old 06-10-2004, 10:32 AM   #5
Member#: 47261
I did it this way...
1. pull fuse #11 (fuel pump)
2. turn on car (let die)
3. try to turn over car couple more times
4. loosen the clamps on the lines
5. pull off the lines (wrapped my hand in a rag to catch any fuel - was a dribble and that's it)
6. pulled off the rubber protector thingy
7. took off the clip that hold the lines
8. installed new filter
9. turn over engin and let run for a little while while checking for leaks from hoses.
All that took all of 5 minutes and there was only a tiny dribble when I pulled off the filter. I'm also told that's the way the mech.s at the dealerships do it.
Old 06-11-2004, 07:05 AM   #6
damianq
Member#: 5380
1999 Impreza
Primer
As long as it works eh?
Old 06-11-2004, 09:11 AM   #7
Member#: 47261
for sure... as long as i works... well
fuel pump fuse? generalwrx Newbies & FAQs 4 12-23-2004 02:55 PM
Fuel Pump Fuse? samli77 Texas Impreza Club Forum -- TXIC 1 02-12-2004 03:51 PM
fuel pump fuse? sparta65 Service & Maintenance 2 08-03-2002 08:46 PM
Location of fuel pump fuse turbonutterbastard Service & Maintenance 1 04-14-2002 10:03 AM
Where's the fuel pump fuse? subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-18-2001 12:16 AM
