Old 06-08-2004, 04:34 PM   #1
Lever2ooo
Member#: 51708
**** your hippy
Default Right Rear of my Car is Higher than the left rear
Ok So I am convinced that the right rear of my car sits about 1 cm higher then the left rear?!?!?!
I have stock MY04 struts with STI Eibach Pro-Kit Springs, and they have been on for about a month this is the first time i noticed soemthing, i havnt hit anything for sure, please let me know whats going on?
edited out swear filter avoidage - S.G.
Lever2ooo is offline   Reply With Quote
Old 06-08-2004, 04:36 PM   #2
AaronWRX
Member#: 7194
2011 997.2 Turbo
Well.. fine a level surface and measure from the ground to the upper most part of your wheel well. Then turn the car around 180degrees and measure again.
Then you wont be convinced, you will know.
AaronWRX is offline   Reply With Quote
Old 06-08-2004, 04:40 PM   #3
Lever2ooo
Member#: 51708
**** your hippy
ok I am going to do that after work, but what could it be??
Old 06-08-2004, 05:00 PM   #4
mnkypsycho
Member#: 43988
springs are not lined up right with the top hat? you have a front spring switched with the rear?? you have one bad shock??? take everything off and see whats up.
mnkypsycho is offline   Reply With Quote
Old 06-08-2004, 05:01 PM   #5
Lever2ooo
Member#: 51708
**** your hippy
i believe the fronts are perfect, the car has like 9k miles so i dont know how i coul have a bad shock but i guess that could be the case, keep the theories and suggestions comming
Old 06-08-2004, 05:15 PM   #6
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
imprezas sit slightly lower on the left side
b_tapper is offline   Reply With Quote
Old 06-08-2004, 05:29 PM   #7
poison
Member#: 37678
You need to go on a diet?
poison is offline   Reply With Quote
Old 06-08-2004, 05:33 PM   #8
Lever2ooo
Member#: 51708
**** your hippy
i thought of that but i weigh 165 lbs
Old 06-08-2004, 05:43 PM   #9
poison
Member#: 37678
I know, you should see how it look when youre sitting in it...
Just kidding!
Is the air even in your tires?
And as someone showed me, the surface should be VERY level, even a small difference can make your car look uneven.
Old 06-09-2004, 10:06 AM   #10
Lever2ooo
Member#: 51708
**** your hippy
bizump!!
one side of my car is higher than the other. refuse Brakes, Steering & Suspension 1 11-11-2006 06:26 PM
Car is pulling to the left and to the right MattDell Brakes, Steering & Suspension 11 08-30-2004 01:29 AM
Someone just keyed the FVCK OUT OF THE RIGHT SIDE OF MY CAR!!!! snipes Texas Impreza Club Forum -- TXIC 22 06-01-2002 01:17 PM
One side of my car sits lower than the other? JGard Brakes, Steering & Suspension 7 05-18-2001 07:58 AM
One side of my car is higher than the other! WRXwannbe Brakes, Steering & Suspension 6 11-15-2000 07:40 AM
