Old 06-08-2004, 10:12 PM   #1
GameOver
Member#: 23145
2004 WRX STi
BLUE
Thumbs down STI Accessport Dyno results....dyno plot attached
Ok guys, here it goes. This morning I drove to south coast subaru to get my accessport. So I got it, loaded the 'stage 2 91 octane' map on the car at SCS's parking lot and drove up to www.harmanmotive.com to dyno the car. So here are my thoughts on it '............' <----Interpret my silence and judge for yourselves.
Please post what you think of 'THIS'.
thanks
......anyone wanna buy the accessport from me ???
later
legend:
blue = pde catted dp + borla 3 inch catback
red = blue + accessport on stage 2 91 octane
GameOver is offline   Reply With Quote
Old 06-08-2004, 10:29 PM   #2
PoG
Member#: 37317
04 STi
White/Silver
What's up with that!
I should have mine this week, I don't feel so excited now
PoG is offline   Reply With Quote
Old 06-08-2004, 10:58 PM   #3
GameOver
Member#: 23145
2004 WRX STi
BLUE
Im about to get depressed!
Old 06-08-2004, 11:09 PM   #4
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
whats the boost at??
Is it so safe its no fun?
tm999xxx is offline   Reply With Quote
Old 06-08-2004, 11:11 PM   #5
GameOver
Member#: 23145
2004 WRX STi
BLUE
18 tappering to like 12 at redline
cant remember exactly
Old 06-08-2004, 11:14 PM   #6
PoG
Member#: 37317
04 STi
White/Silver
Have you tryed a different map (91 octane) or even stage 1.
I wonder if the ECU is still learning your setup (non-cobb TBE)
Old 06-08-2004, 11:16 PM   #7
GameOver
Member#: 23145
2004 WRX STi
BLUE
the stage 1 91 0ctane map gave me like 5 hp less
Old 06-08-2004, 11:24 PM   #8
PoG
Member#: 37317
04 STi
White/Silver
If you get some answers from cobb, let us know.
Old 06-09-2004, 12:10 AM   #9
SemperFiSti
Member#: 51715
2004 Sti
Did you download the new map management software released yesterday?
SemperFiSti is offline   Reply With Quote
Old 06-09-2004, 12:36 AM   #10
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
The 2.0L maps don't taper boost that much. My stage one tapers from about .1 MPa to about .09 MPa.
I would follow SemperFiSti's lead and make sure the AP is really changing your boost targets properly.
The torque curve you posted does not look like a typical reflashed curve.
brizey is offline   Reply With Quote
Old 06-09-2004, 12:39 AM   #11
GameOver
Member#: 23145
2004 WRX STi
BLUE
Nope, no new software downloaded.
Old 06-09-2004, 12:43 AM   #12
brizey
Member#: 36505
Also, you are making a crap load more power between 3000 and 4000 rpm, like 40 whp. That has to register on the butt dyno.
Also, if it works like the 2.0 AP, give it a day or so and a few software releases. And be prepared for "restrictor" fixes and the like.
Old 06-09-2004, 12:52 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Wow... that dyno plot looks like someone was haveing a seizure. Dyno plots realy should not look like that...
You know that it takes a while for the ecu to get used too the new settings... Your making a 20lbs of tq gain, and thoes numbers will go up as everything settles.
Old 06-09-2004, 12:53 AM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
Check out the new software... http://www.cobbtuning.com/sti/accessport/
Old 06-09-2004, 01:03 AM   #15
cnk
Member#: 10757
2013 BRZ Limited 6MT
It should get faster as you drive it more. . at least that's how it's been with most ECU reflashes. I have an Ecutek reflashed ECU and another ECU with AP waiting to go on for comparison once they come out with a map for a FMIC. From what I've read from other AP users, it takes a few days for the ECU to learn and the car smoothens out and gets faster. If you just flashed the car and put it on the dyno, the ECU was most likely still learning.
Calvin
cnk is offline   Reply With Quote
Old 06-09-2004, 01:20 AM   #16
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That doesn't really surprise me on 91 octane gas. You did make 24 ft-lbs more torque and more hp through the midrange powerband. The accessport just doesn't run much boost at higher rpms on the 91 octane maps for safety reasons but you can see what it does in the low end. At 3500rpm you are making 50 ft-lbs more torque than stock... Remember their stage2 dyno plots on their page are using a stock STI, not one with a different exhaust or any other modifications. It's also running 93 octane gas.
Old 06-09-2004, 01:21 AM   #17
WRX Jim
Member#: 22321
graph looks funny because it needs smoothing
WRX Jim is offline   Reply With Quote
Old 06-09-2004, 01:32 AM   #18
totoherbs
Member#: 7321
.... 122 IggPoints
What? That has nothing to do with the imput its getting from the car... thats the dynos problem. Torque does not move up and down as much as 5 to 10 lbs in 20-30 rpm.
Old 06-09-2004, 01:53 AM   #19
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
I think with one more day of driving you will definitely have a bigger and smoother power increase.
AndyM is offline   Reply With Quote
Old 06-09-2004, 02:03 AM   #20
Dynamispeed
Vendor
Member#: 51291
The Cobb setup is a generic map. It is designed to keep your car nice and safe. This is fairly typical of flashes like this. I only like to custom tune cars to around 90% (unless the owner wants the car on the edge). A generic reflash may reflect around 80% comparatively. Cobb has to account for a worst case senario and develop a baseline from there. The pecentages above are subjective, and are merely used to make my point. They don't reflect power necessarily, but just the amount of safety in a tune.
That being said, 20 lb ft of torque is a ok gain. A custom tune will give you more of the gains you are looking for. You will never get all out performance with an over the counter map or tune. It sounds like a UTEC or UNICHIP may be more along the lines of what you are looking for. The drive between Harman Motive and South Coast Subaru should have been enough time for the car to "learn" what it needed to. Espically if you reset the ECU beforehand.
Comparatively, a car that we set up made 343 lb ft of torque and only 293 HP on that same dyno. We used a Dynamispeed stage 1 on that STI (GP MOTO header, turboback, intake and GP MOTO PNP Unichip) w\ the stock VF39. The map on that car was our generic baseline map that I usually tune from. The top end is very conservative w\ timing which accounts for the low power on the top end. Typically cars pick up 25-30+WHP after fine tuning.
I can scan the dyno sheets if you would like to see them.
Just some food for thought.
Regards,
Ashley
Dynamispeed
Dynamispeed is offline   Reply With Quote
Old 06-09-2004, 02:39 AM   #21
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
Ashleys rite on the bar with his response, keep in mind Trey and Cobb Tuning are very good tuners, yet they tune at a safe level, that will keep the car at the bare minimum, there are other tuners and ecu upgrades available that will squeeze every ounce of power out of the sti.
Keep in mind the sti is a beast from the factory to begin with, as it is aggressively tuned close to its peak, so the difference may not be as subastantial as it would be with the Impreza WRX model which was detuned to begin with....
Honestly i expected this outcome as it is the same as the WRX Accessport that was released, gained about 40-50bhp at the flywheel +/-5. What Cobb has in store for the Accessport is something to rejoice about as soon many Cobb tuned cars will have the ability to play and custom tune to their interest with the release of the AP Street Tuner and Pro Tuner. The maps as of yet are just that base generic maps, but soon the difference of the ecutek and cobb and alike will be differentiated as the ease of use with the AP is outstanding, what other ecu upgrade will let you change maps on the fly and still retain your ecu 100 flashes? and the like.... The port itself if really cool...
hands up to cobb, and for those looking for tremendous power i agree you wont find it on the AP just yet, but stay tuned....
hyp36rmax is offline   Reply With Quote
Old 06-09-2004, 03:56 AM   #22
GameOver
Member#: 23145
2004 WRX STi
BLUE
Ill give them credit for the map change on the fly
But yeah, Ill drive it like a week or so and then maybe dyno it again.
Old 06-09-2004, 08:32 AM   #23
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I'm not sure why you responded that way but the graph does look like that because it's not smoothed, which is the dyno software. All raw dyno plots look something like that and the software is responsible for making it look pretty.
Old 06-09-2004, 09:24 AM   #24
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
You've got to look at area under the curve. Everyone is so hung up on peak hp increase and peak torque increase. Between 2900 and 4000 you're making gobs more torque. That's the sweet spot on the stock turbo that should make the car feel tons faster. Hell, at 3400 rpm you're making almost 70 more ft/lbs. And 40 more hp at 3500 rpm.
Seems like good gains for a generic map on 91 octane.
Frank
fmowry is offline   Reply With Quote
Old 06-09-2004, 10:30 AM   #25
jamesohoh7
Member#: 39070
GTF off my lawn!
Frank
Bingo! I was going to post 'area under the curve' as well until this post... so now, I'll just 'ditto' it. I can't imagine that the car doesn't feel noticably gruntier down low to mid... right where you use it most day to day.
I bet it picks up more over the next few days... my AP Stage2 flash took a few days to 'optimize' itself.
-James
jamesohoh7 is offline   Reply With Quote
HELP! lost 30hp... plots attached wobbletop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-31-2006 09:00 PM
MZM AWD Dyno Day ~ Results Dyno Plots keyser_soze Proven Power Bragging 28 10-15-2005 05:00 AM
My dyno results Accessport Stage 2 file_id Proven Power Bragging 48 12-30-2004 07:53 PM
STi Accessport Dyno results are up at cobbtuning.com volkl23 Engine Management & Tuning 13 05-31-2004 07:43 PM
STI dyno results fi-systems Texas Impreza Club Forum -- TXIC 28 07-08-2003 12:33 PM
