Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 06-08-2004, 11:28 PM   #1
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Question coolant leak - from oil filter?
Driving home today, i noticed I did not have any AC comming through my vents. Finally when I got home, I noticed that my temp gauge was pointed straight-up to the H!!!
I immediately popped open my hood - nothing left in the coolant resevoir tank. This is NOT a good sign. I just did an oil change last Friday afternoon. The oil that drained out was black as normal. Oil filter was relatively clean. I made mental note of the coolant in the resevoir tank - it was at the Full line - everything normal.
Today however, with my "overheating" problem and zero coolant in the resevoir tank, I went poking around - looking for any headgasket leaks - nothing from the outside.
However, when I poked my head underneath my car, I could clearly see coolant had somehow leaked onto my oil filter as well as part of my passenger side header. I cannot see any visible leak sources! HELP! What should I do? Should I temporarily fill with water so I can take it to the dealership to get it checked out?
I just rolled over my 100k km warranty.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 06-08-2004, 11:51 PM   #2
Schlogen
Member#: 59118
2016 WRX
Pure Red
ever use that subaru additive thats supposed to stop some sort of head gasket leak? if not id bet thats it
Schlogen is offline   Reply With Quote
Old 06-09-2004, 12:25 AM   #3
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
That would suck very much. I guess you could add water into radiator and drive slowly to dealership and have them check out.
Jason is offline   Reply With Quote
Old 06-09-2004, 01:00 AM   #4
Penphoe
Member#: 269
Well, it looks like I've got a radiator leak.
I filled my radiator up tonite and let it idle till it was up @ "normal operating temp". Look at these pictures I took afterwards.
All these photos were taken underneath the car, looking up towards the radiator on the passenger side. Looking up from the top, I don't see any leaks.
Sux to be me.
LaterZ!
Darren!!
Old 06-09-2004, 02:42 AM   #5
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Did SOC not do a recall to have that taken care of? You should take it to the dealer and have it repaired if so.
joubtt is offline   Reply With Quote
Old 06-09-2004, 03:04 AM   #6
Penphoe
Member#: 269
I don't have a headgasket problem. I've got a radiator problem - I've got a leak somewhere in my radiator which caused all of my fluid to leak out. I thought it might be a headgasket problem, bu t it obviously isn't. I don't have white smoke comming out of my tailpipe, and coolant has not mixed with my oil.
That being said, I'm debating whether or not to do a radiator fix myself.
Should I replace the hoses and thermostat while I'm at it? I'm currently over 100k kms (about 60k miles).
LaterZ!
Darren!!
Old 06-09-2004, 03:13 AM   #7
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Also check on the overflow tank, there is a small breather hole near the neck. If you keep it dirty, you might see a trail of dried coolant from there, carried downwards with the airflow while the car is moving. It'll leak from that hole if the level gets waaaay high.
Ken is offline   Reply With Quote
Old 06-09-2004, 03:43 AM   #8
dugrant153
Member#: 22505
1985 Old
Rusty
dude, my Corolla just had the same problem. and now it's sidelined for now can't afford to fix it right yet...
I feel your pain. puff of white smoke out the tailpipe. overheating... *sigh*... sounds exactly like my problem.
hope you fix it up, man! check for headgasket leaks anyways. apparently there's two types of coolant leaks or something? one that's internal and the other external... or something like that.
dugrant153 is offline   Reply With Quote
Old 06-09-2004, 08:44 AM   #9
Frawl
Member#: 19201
2008 Legacy Wagon
Now that sounds like a head gasket!
Penphoe you need to isolate the source of that leak. As you know there's lots of coolant system nodes/connections etc. So it might be somthing simple like splitting hose, or maybe a failing gasket on your water pump. Because the system is under pressure, it doesn't take much for a small leak to get messy. It also doesn't take much for a small leak to become a much bigger leak. Good luck. Don't let it get you down man!
Jeff
Frawl is offline   Reply With Quote
Old 06-09-2004, 09:56 AM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
is that stuff you pour into your coolant (i think it's called "bar's leaks) safe for sealing radiator damage like this?
Benjamin Tang is offline   Reply With Quote
Old 06-09-2004, 10:17 AM   #11
Penphoe
Member#: 269
Jeff
I think I have - I have a feeling it's the bottom of the radiator that's leaking.
When I checked last nite, the water pump was fine, and so was the thermostat - no leaks in that area. My hypothesis is that the leak is somewhere near the bottom of the radiator by the passenger-side fan. When the fan kicks on, it blows the coolant backwards towards the oil filter and header. That's why there's so much residue there.
There's no white smoke comming from my exhaust at all - was checking my rear-view mirror as well as took a quick peek as it was idling. Definetly not a headgasket.
I hope it's a simple radiator fix - anyone know what is a good aftermarket radiator to replace the OEM one with?
LaterZ!
Darren!!
Old 06-09-2004, 10:19 AM   #12
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Let it be known that the "known" issue with the headgaskets that resulted in a recall does not result in a failure of the HG between the waterjacket and combustion chamber. Thus you would not have mixed oil/water or white smoke. The problem the recall was for is for a failure bwteen the waterjacket and the "outside world"....
Looks like you have a busted radiator... the hole may be small, but once the system pressurizes, it can force the liquid out...
Texas25RS is offline   Reply With Quote
Old 06-09-2004, 06:35 PM   #13
Schlogen
Member#: 59118
2016 WRX
Pure Red
check the vendor forums. i saw some aftermarket radiators over there
Old 06-09-2004, 07:10 PM   #14
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
could it be a stuck or broken thermostat, if it gets stuck closed it should really pressurize your rad and force the liquid out ,I would check that before I buy a new rad, 20$ part vs 200$+ part
4wheelflyer is offline   Reply With Quote
Old 06-09-2004, 08:53 PM   #15
Penphoe
Member#: 269
If that's the case, then wouldn't it be leaking through the overflow tank? My overflow tank was empty and bone dry.
However, the bottom of my radiator was dripping wet.
I did more poking around just now. I removed the radiator fan to see what was going on in front of it. Underneath the fan, is a little "tray" for the bottom end-tank. There's a little pool of coolant down there. It looks like I"m leaking near the bottom of my radiator on the passenger side.
LaterZ!
Darren!!
Old 06-09-2004, 09:31 PM   #16
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I recently replaced my radiator. I pressurized the coolant system through the overflow tube just below the cap with @15psi and found that the lower log of the radiator had a nice leak. It would only leak when pressurized(obviously I guess). Yours looks much worse, like a total failure of the lower log.
I say yes to the new t-stat.
Hopefully you did'nt warp anything.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 06-10-2004, 12:50 AM   #17
Penphoe
Member#: 269
Good luck
Did you do the job yourself? Did you replace the hoses while you were at it? What's your mileage at?
LaterZ!
Darren!!
Old 06-10-2004, 10:12 AM   #18
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Yes, did it myself.
Yes, I replaced the lower hose.
At the time the car had @100k.
Old 06-11-2004, 02:15 AM   #19
Penphoe
Member#: 269
Well, the radiator is now out. I took it out this afternoon. Hopefully I'll have a replacement radiator by friday nite/saturday.
So, any suggestions on what to fill the radiator with? How should I mix the coolant?
LaterZ!
Darren!!
Old 06-11-2004, 02:55 AM   #20
joubtt
Member#: 33901
04 04 STI
50/50 distilled water/coolant(SOA) + coolant additive from SOA. OEM stuff.
Old 06-12-2004, 06:07 PM   #21
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Looks like you ran over a "Predator". Good luck.
garface is offline   Reply With Quote
Old 06-14-2004, 10:11 AM   #22
Penphoe
Member#: 269
Well she's all fixed. This past saturday, I spent the morning installing a new radiator, thermostat, and putting everything back together. I filled her up with a 50-50 mixture of coolant and water. No problems whatsoever. I didn't even have to spend much time burping the air out of the system either! Now the temp needle sits at just below the half-way mark just like it did before!
LaterZ!
Darren!!
Old 06-14-2004, 11:21 AM   #23
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Awesome! Feels good not getting hammered in the rear by a dealer for relatively easy work hey?
Good job.
Old 06-14-2004, 01:32 PM   #24
Hayes
Member#: 11808
You don't mention that you got the SOA "coolant system conditioner" put in. Do it (it's free) and your head gasket waranty goes up to 8 years or 100,000 miles. Don't use Bars stop leak or anything other than the dealer installed SOA stuff.
Hayes is offline   Reply With Quote
Old 06-14-2004, 03:40 PM   #25
Penphoe
Member#: 269
I haven't heard if anything like that is offered up here in Canada. I should go check that out. I'm already over my 5-year 100k km powertrain warranty.
Thanx.
LaterZ!
Darren!!
Coolant dripping from oil filter? 03WRX_Rich North West Impreza Club Forum -- NWIC 5 12-15-2008 03:10 PM
Oil/Coolant leak from GT35R the_owl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-18-2005 04:55 PM
XT coolant leak, by oil filter? jukes Forester Forum 7 03-09-2004 12:35 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
Car leaking oil from oil filter... SubaruImpreza_power Forester Forum 30 12-01-2003 09:32 AM
