Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 06-09-2004, 12:46 AM   #1
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
Default rs breaks on ts?
im 99% sure GC RS breaks fit the GC TS, but that doubt lingers. its a direct bolt in and the entire assy (rotors, bracket and calipers) clear the 15" stock TS rim right?
MixeD_MenacE is offline   Reply With Quote
Old 06-09-2004, 03:06 AM   #2
damianq
Member#: 5380
1999 Impreza
Primer
YUP! Just slide on the rotor, bolt on the braket, then caliper w/ pads already installed, bolt up, drive away. I have it on mine. It does clear the TS wheels w/ ease. A few of the other OEM 15" wheels will not fit, but most do fit the RS brakes. The WRX front brakes will only fit behind the 99-01 TS 15" stockers, no other OEM 15".
The rear disc conversion is a whole other mess. Not worth it in my opinion unless you are doing motorsports in which one can benefit from some race pads.
damianq is offline   Reply With Quote
Old 06-09-2004, 07:38 AM   #3
MixeD_MenacE
Member#: 1274
MY00 BRP 2.5RSTi
www.zucru.ca
will the stock steelies fit it? you mentioned some oem 15's don't fit, which ones? i don'tknow if there is a difference between he 98 "L"s and the 99-up TS's
Old 06-10-2004, 10:03 AM   #4
damianq
Member#: 5380
1999 Impreza
Primer
To be honest, I've never tried the stock steelies, so I don't know if they fit or not. All I've had are OEM alloys. Sorry I couldn't be of more help.
Old 06-10-2004, 06:44 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Just check on the rim... if it's a 15x6JJ wheel, you should be fine....
I have 2 set of forester steel wheels and they fit fine.
Robin
Robin2 is offline   Reply With Quote
2000 RS exhaust on a 02 TS? dlong27 Newbies & FAQs 2 10-28-2008 09:45 PM
DIY painting side mirrors on TS, RS, or 2.5i's ralli-tart Interior & Exterior Modification 2 07-09-2008 06:31 AM
stock RS breaks vs stock WRX breaks (wheel clearance) Osgood30 Tire & Wheel 1 10-31-2003 02:13 PM
Goodbye Pinion Bearing...record for most bizzare things breaking on my RS? munkis General Community 6 08-04-2002 07:15 PM
Subaru releases pricing on TS, RS, OBS Gearhead_42 General Forum Archive 18 02-10-2001 12:52 AM
