Old 06-09-2004, 09:09 AM   #1
ttoversteer
Member#: 465
2012 GTI
Gray
Question Oh no! Not another clunking thread!
And yes, I tried searching.
Here's my setup (GC8): Whiteline front and rear swaybars and endlinks. 165,000 miles.
I get a clunking from the front of the car at very slow speeds, straight line, over rough pavement. The sound comes from both sides at random, and I can occasionally feel it through the steering wheel. As it is becoming more frequent, I am also hearing it at speeds up to 60mph when I hit short, sharp bumps or depressions.
It is NOT a wheel bearing or CV (Both sides are new). The sway bars have been on the car for at least 100k miles, so I really don't think that is the problem, and I recently lubed those bushings.
I think I have it narrowed down to the control arm bushings being worn out; there is some play when I stick a pry bar in there and wiggle it around.
Does anyone have any thoughts on this, or similar experience?
Thanks.
ttoversteer is offline   Reply With Quote
Old 06-09-2004, 09:47 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Might be a ball joint also.
scoobyimprza is offline   Reply With Quote
Old 07-01-2004, 10:40 PM   #3
mj13young
Member#: 37735
2004 wrx sti
Default its the ball joint
Its the ball joint. I had the same symptoms on my wrx wagon.
mj13young is offline   Reply With Quote
Old 09-24-2004, 11:59 PM   #4
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
Well What Was It?!?!
96Imprezadent is offline   Reply With Quote
Old 09-25-2004, 02:32 PM   #5
ttoversteer
Member#: 465
2012 GTI
Gray
Heh. I forgot all about this thread.
It turns out that it was either the bushings that connect the front control arms to the frame of the car, or the top mounts. I replaced them at the same time, and the sound went bye-bye. If I had to narrow it down, I'd say it was the bushings; there was significant play when I stuck a pry bar and wiggled.
Wasn't a ball joint: I had replaced both of the front ball joints not too long prior. Now that I think about it, just about everything related to the front suspension/steering/wheels has been replaced.
I hope this helps.
Oh no not another clutch thread! travisatlarge Transmission (AT/MT) & Driveline 2 03-26-2008 08:36 PM
Oh no... not another Tokyo Auto Salon 2008 thread... BlackStar Member's Car Gallery 45 01-15-2008 10:03 PM
Oh no, not another brullen header review! direwlf Normally Aspirated Powertrain 4 01-13-2002 12:27 AM
oh no, not another Rogers thread from me!! jackwei Vancouver Impreza Club Forum -- VIC 7 11-13-2001 05:37 PM
