Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-09-2004, 01:17 PM   #1
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Default Manual Boost Proplems
I just added a K&N HIgh Flow filter and Go Fast Bits atomic manual boost controller to my '04 WRX. It's running just unter one bar (14.5 pounds) and not only is my check engine light on, but the idle is running like it's really rich too. I was thinking of getting the MIL Check Engine Eliminator, but didn't know if this would correct the problem with the idle. Any suggestions? Thanks.
doster82 is offline   Reply With Quote
Old 06-09-2004, 01:52 PM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
CEL is prolly on cause you spiked in 5th, don't run a MBC on a car without engine management... ESPECIALLY not an 04 are you nuts?
overdose is offline   Reply With Quote
Old 06-09-2004, 02:19 PM   #3
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Hadn't heard of problems with others systems w/o EM. Think I should remove it?
Old 06-09-2004, 02:23 PM   #4
RussB
Guest
Member#: 43667
yes. the mbc will allow you to hit full boost at partial throttle, in a range where the ECU things you are building much less boost and not providing enough fuel to support what it actually is boosting. that causes lean conditions and very high exhaust gas temps. also, as for MIL eliminators... only run those if you purposefully did something to your car that can cause a CEL like going catless. the light is there for a reason. if you installed an MBC, and the light comes on and the car runs like ass, something is wrong and you should get it checked out instead of deactivating the light.
RussB is offline   Reply With Quote
Old 06-09-2004, 02:25 PM   #5
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
You are getting a check engine light and you want to eliminate it? Do you know what code is in the ECU?
Take off the MBC, get your CEL code read (and NOT under warranty), fix your problem, get an Accessport.
mrbigisbudgood is offline   Reply With Quote
Old 06-09-2004, 02:31 PM   #6
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Where can I get the Accessport? Est. $?
Old 06-09-2004, 02:39 PM   #7
Calsoldier
Member#: 56538
2004 WRX
Can you change boost levels with the accessport?
Oleg
Calsoldier is offline   Reply With Quote
Old 06-09-2004, 02:39 PM   #8
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
$600, Just drive over to Cobb's. They are right in your town.
oops. Call first and order then drive over a few months later to pick up.
GDR is offline   Reply With Quote
Old 06-09-2004, 02:49 PM   #9
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Until then, just take out the MBC, get the ECL checked, and stick it out stock? Can anybody check it w/o it going on my warranty?
Old 06-09-2004, 03:18 PM   #10
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
spend a lot of time reading on this forum, i bought mine in october 03 and i've learned quite a bit since then.... bottom line with these cars is engine management first and foremost, then focus on the bolt ons like uppipe/downpipe/exhaust
Old 06-09-2004, 03:38 PM   #11
gr8-wrx
Member#: 38411
2003 WRX Sedan
2001 Honda CR-V SE
gr8-wrx is offline   Reply With Quote
Old 06-09-2004, 04:02 PM   #12
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
So, although factory boost is way under what the engines can handle, MBC's aren't a good idea until you've got the ECU under control?
Old 06-09-2004, 04:07 PM   #13
subindiego
Member#: 48825
2004 WRX sedan
You should talk with the people at modern garage and Cobb tuning, they are at 4673 s. cherry st. in your home town. They will stear you in the right direction for increasing your HP reliably.
Go to www.cobbtuning.com for more info.
Get engine management, the accessport from cobb is a great first step. Waiting on the AccessPORT sucks but is well worth it. Since you live in SLC you could just have them reflash your ECU with a stage 1 map.
Yes it does raise boost slightly, it also changes the timing and the a/f ratios. It is the combination of these changes together that allows HP to be increased without detriment to reliability.
Raising boost alone can be a risky venture if you are not careful.
subindiego is offline   Reply With Quote
Old 06-09-2004, 04:10 PM   #14
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
There ya go.
Old 06-09-2004, 04:22 PM   #15
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
"you could just have them reflash your ECU with a stage 1 map"
Would I still be able to keep the MBC without it having a detrimental affect on my engine?
Old 06-09-2004, 04:26 PM   #16
RussB
Guest
Member#: 43667
you won't need an MBC with a reflash.
Old 06-09-2004, 04:31 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
pull your maf sensor. it is probably liberally coated in the oil that k+n overapplies to the filters as they ship them. clean it.
edit: clean it with non chlorinated brake cleaner. get a ziploc bag, spray cleaner inside, put sensor inside, close bag, shake it around. the brake cleaner comes out with a lot of force and can damage the very thin wire of the maf sensor.
i love my mbc, but putting one on an 04 is not suggested due to the slow transition from closed to open loop fueling. the mbc's very quick response will make detonation almost certain.
jm2c
ride5000 is online now   Reply With Quote
Old 06-09-2004, 04:34 PM   #18
h8ual
Member#: 22437
03 WRX
hey doster...
I have run a MBC for over 40k and it has been no worries. what you probably did was push over 17lbs of boost and then threw the CEL. that is bad but should not cause any real damage to the car. the first thing you should do is crank the boost down to 15lbs. 15.5 max. in 3rd gear! (what are you measuring?) anything more can't be utilized due to the size of the turbo so you will get diminished returns on anything more.
engine mgmnt is not something you have to have to go a little faster. you definitley need it to go a lot faster though.
i run 8.7 in the 1/8 mile with just a boost controller set to 15lbs. and some BFG tires too...
here is how you fix the check engine light.
disconnect battery---with the key turned so the radio and lights will run--then stomp on the brake pedal and purge the last electrons from the system by lighting the brake lights and the CEL should go away. this won't fix your idle problem. don't know what that is.
good luck...
h8ual is offline   Reply With Quote
Old 06-09-2004, 04:45 PM   #19
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
Thanks h8. I'm gonna run to Autozone to get the CEL checked, but I'll do that. And I checked out the accessport, think I'll head over to Cobb tomorrow. Any more suggestions? I'm actually running 15 pounds at 3rd gear, but do think I spiked it when driving it last night.
Old 06-09-2004, 04:46 PM   #20
mixup52
Member#: 39691
2002 WRX Wagon
You really don't need to go to cobb, you could get a UTec and we could help you tune it. We have all the proper equipment to do the tune. Cobb is not the only option. I prefer the Utec myself. The reason is that everytime you upgrade, you need to get it retuned and at 214.00 an hour @ MG - Cobb that gets really expensive.
You can go to Autozone and get the code pulled. Then come back and let the board know what it was, that will help us to determine what the problem might be.
IF you need any other help you can PM me since I am kinda local.
Chris
mixup52 is offline   Reply With Quote
Old 06-09-2004, 05:08 PM   #21
doster82
Member#: 61845
MY06 Legacy GT 5MT
Regal Blue Pearl
I was actually planning on going with the UTEC initially, I like the idea of the Piggyback, but also like the Cobb just because of ease of use. I've also been working with Scott, Matt, and Vesco over at TDC Motorsport (aka Scoobytuner), and they've been pretty helpful. I could always use your input on these situations, though. So, the general thought is I should remove the MBC, though? Yes/no?
Old 06-09-2004, 05:48 PM   #22
mixup52
Member#: 39691
2002 WRX Wagon
Yes.
Old 06-14-2004, 09:04 PM   #23
Magman
Member#: 40038
2002 Impreza WRX
Default got ecu?
yes yes.
cobb or utec, thats up to you. i had my ecu reflashed by cobb, and i absolutely loved it. very good for daily drivers, and no worries tuning. later i bought the accessport (150) and i love that too. especially the live boost function. now i have an uppipe and that caused boost fluctuations, so my friends and i jigga rigged a MBC so that my boost is constant. no cel codes. runs fine. in conclusion, get engine managment so the ecu will work for you, and not against... then put on your bolt ons. (plus EM makes all your bolt ons even more effective because you can tune for them)
Magman is offline   Reply With Quote
boosting proplems blackout801 Rocky Mountains Impreza Club Forum -- RMIC 10 03-19-2008 10:43 AM
Is a manual boost controller the best way to add a bit of boost? rsilvers Engine Management & Tuning 3 09-23-2004 10:24 AM
TN: OEM Boost Gauge and manual boost controller - $85 Dracon Private 'For Sale' Classifieds 10 02-20-2004 05:21 PM
Manual boost controller vs Digital boost controler ScoobieSnacks Bay Area Impreza Club Forum -- BAIC 27 02-17-2002 06:28 PM
