Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 06-09-2004, 05:17 PM   #1
Brian204
Member#: 56528
1989 GL
white
Default is this sound anything to worry about?
Hi all,
When I'm cruising down the highway, 45 mph+, i've noticed a faint, smooth, noise. Perhaps like some sort of friction. It almost sounds like it would be road noise except that it is silent when turning the wheel to the right. Its very faint, I only noticed it because I had the radio off, but it struck my curiousity. We've never replaced the CV joints or shafts, but the boots are in good shape. 209k mi. One boot was replaced a year or two ago. The car drives as smooth as always, minus the 60+ shimmy I'd thought was normal on all of them. Any thoughts or am I just paranoid?
thanks,
Brian
Brian204 is offline   Reply With Quote
Old 06-09-2004, 05:35 PM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
DOJ or wheel bearing would be my bet. Nothing to worry about ... yet... it will be sometime down the road though.
Calebz is offline   Reply With Quote
Old 06-09-2004, 09:20 PM   #3
Brian204
Member#: 56528
1989 GL
white
I was poking around under there, and on the left half axle, i can pull it toward the wheel considerably, enough for it to clank against whatever it hits whatever is at the end of it (socket?)...could this give a more accurate diagnosis?
Old 06-10-2004, 12:43 AM   #4
Calebz
Member#: 54398
1980 CB400 Hawk
ummm.. odd description...
Is it possible the large nut(castle nut) on the end of the axle isn't tight.
A little side to side play is normal.
Bring it over and I'll have a look at it for you
Old 06-10-2004, 04:13 AM   #5
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Theres at least 2in of play in the DOJ(ok, I might be exagerating a little), but its still alot. I wouldnt worry about it. It sounds more like tire noise your hearing. How much tread is on the tires? And what kind of tires/tread are they?
TurboneX is offline   Reply With Quote
Old 06-10-2004, 05:15 PM   #6
Brian204
Member#: 56528
1989 GL
white
The tires are pretty new, I might check the castle nut. Otherwise, if some free play is normal on the shaft, I'll just drive 'er and see what happens. Thanks guys.
Brian
If you're not doing anything wrong, you don't have anything to worry about. Corn-Picker Political Playground 7 07-24-2008 12:08 AM
Rear ended in parking lot...anything to worry about? RallyLegacy Service & Maintenance 5 04-18-2008 08:27 AM
'98 RS heagasket anything to worry about? jamesfacts Normally Aspirated Powertrain 11 02-04-2004 06:28 PM
Getting 91 MR2 - anything to worry about? WRXVII Off-Topic 16 10-05-2003 01:50 AM
Anything to worry about...? XROLLER Brakes, Steering & Suspension 4 05-15-2002 12:04 PM
