Old 06-09-2004, 08:59 PM   #1
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Default what radiator options do i have 99 RS?
just what i said
jeff22 is offline   Reply With Quote
Old 06-09-2004, 09:09 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
C&R and Koyo are the only 2 IIRC.
kastle is offline   Reply With Quote
Old 06-09-2004, 09:16 PM   #3
Wedge
Member#: 2279
2000 Slingshot/99RS
Pastelito Racing / SFSOC
And FYI on the Koyo, the stock fans will not bolton and expect to them to fit.......to thick, you need flex-a-lite fans. Just finished doing this.
Wedge is offline   Reply With Quote
Old 06-09-2004, 09:46 PM   #4
Unsung Boxer
Member#: 37196
you could always put an L one in. Ive never understood these radiator upgrades... what is the benefit? Isn't money better spent somewhere else?
I am running 12 psi on an EJ22na/t block and my temperature is perfecly find w/ stock radiator.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-09-2004, 10:15 PM   #5
Wedge
Member#: 2279
2000 Slingshot/99RS
Extensive track usage.
Old 06-09-2004, 10:48 PM   #6
Unsung Boxer
Member#: 37196
does a stock radiator really not hold up to track usage? I mean, how long is a coarse? And more importantly, how many people do endurance races? Ive beat the hell out of my car for about 15 minutes at a time, and Coolant temperature never really gets that high, plus im only using an L radiator.
Anywhoo, im not debating that an aluminum one is better, but it just seems to me that money can be better spent elsewhere.
-Jake
Old 06-10-2004, 09:36 AM   #7
Wedge
Member#: 2279
2000 Slingshot/99RS
But, you're in WA, I'm in South Fl.
Old 06-10-2004, 10:41 AM   #8
Unsung Boxer
Member#: 37196
thats probably true, i dont think i even need a radiator up here... i could just let it air cool.
-Jake
Old 06-10-2004, 01:07 PM   #9
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Summer in Phoenix, AZ... temps are regularly over 100*, long spans of days 110*+. Over 100* starting in May and runs till Octobert...
I've been out here when it was 124* out.
That's why I upgraded my radiator. I would agree that if you lived somewhere cooler, like Alaska for instance, money better spent elsewhere (like a battery warmer... )
Old 06-10-2004, 01:13 PM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
do you guys notice a huge difference?
HOK is offline   Reply With Quote
Old 06-10-2004, 01:18 PM   #11
Wedge
Member#: 2279
2000 Slingshot/99RS
Not unless you have a different thermostat (I believe the STi ones open sooner), which I've been trying to source with no luck.
Have any of you guys heard this?
-Vic
Old 06-10-2004, 07:32 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the JDM sti (GC8) and Sard (I've read)...two more options...my L stock radiator doesn't get the job done...I'm buying a radiator...
Old 06-11-2004, 02:03 PM   #13
Wedge
Member#: 2279
2000 Slingshot/99RS
Found out a company called Crucial makes a cooler thermostat for our cars.
http://www.crucialracing.com/
Website seems to be down though.
Old 06-11-2004, 02:08 PM   #14
kidatari
Member#: 10441
The Koyo radiator is no joke, that thing is huge! The only way to run it and keep your A/C and power steering is to use some very thin fans, as Wedge said. It is a nice piece, though, I'll have one eventually.
kidatari is offline   Reply With Quote
Old 06-11-2004, 02:38 PM   #15
Wedge
Member#: 2279
2000 Slingshot/99RS
Yes! Check out some pics Nino took of his setup:
Old 06-11-2004, 08:16 PM   #16
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
HAHAHAH theres not way that will fit in my car with IC tubing... I guess i;ll count on the -20 weather...
Old 06-12-2004, 11:53 PM   #17
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
I've ran my car pretty darn hard with my stock RS radiator on 100+ degree days here in CO without too much of an issue. A cooler thermostat won't really help keep your car cool if you are beating on it, the coolant flow rates and amount of coolant exposed to air is what determines how many BTU's can be sucked out of the motor, not what temp. the thermostat opens up. All a lower temp. thermostat will do is kill your gas mileage around town because the ECU will think the car never hits operating temp and will run richer.
no-coast-punk is offline   Reply With Quote
Old 06-13-2004, 01:58 AM   #18
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & 06 MCS
Can someone measure the stock rad? I have been looking into just getting a custom rad, but if I can retro fit one of these then that would be good.
subiekid is offline   Reply With Quote
what other options do i have for rear view camera? 06D Car Audio, Video & Security 1 06-02-2010 12:04 PM
Car came with intake, what AP options do I have? ST3 Factory 2.5L Turbo Powertrain 1 04-02-2006 12:25 AM
what exhaust options do i have? David Medina Factory 2.0L Turbo Powertrain 2 07-11-2004 11:02 PM
What swaybar options do I have? Homemade WRX Brakes, Steering & Suspension 2 11-26-2003 09:02 AM
What other options do I have for quality injectors besides the STi's? DannyGT Factory 2.0L Turbo Powertrain 28 05-02-2002 04:41 PM
Message Board Statistics All times are GMT -4. The time now is 08:32 PM.
