Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > WRX Forum Archive
Old 02-24-2001, 11:59 AM   #1
crawdog00
Member#: 4185
Question Does the WRX use a BV or a DV
Hey everyone,
My previous car was a 1.8T GTI, and it had a Diverter valve (DV) instead of a Blowoff Valve (BV). I was wondering if the WRX has the same type of system.
crawdog00 is offline
Old 02-24-2001, 04:00 PM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
BOV.
Imprezer is offline
Old 02-24-2001, 04:50 PM   #3
CP
Member#: 3522
1997 A4 1.8TQMS
Pearl White
Post
BOV that vents to where? I thought venting to the atmosphere was illegal now.
CP is offline
Old 02-24-2001, 05:22 PM   #4
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
It vents back into the intake plumming, after the MAF.
Ken
DeliciouSpeed is offline
Old 02-24-2001, 05:42 PM   #5
adam99rs
Member#: 20
Post
BV and DV are the same exact things...just different names (in Europe, they are usually called DV's). On the WRX and 1.8T, it is vented back to intake.....I don't know of any cars where the valve vents to the air from the factory....anyone?
adam99rs is offline
Old 02-24-2001, 06:33 PM   #6
CP
Member#: 3522
1997 A4 1.8TQMS
Pearl White
Post
So, if you install a blowoff valve, how do you let the computer know that it is releasing pressure? The computer thinks that this pressure is being re-routed back into the intake tract, right, thus administering more fuel, giving you a rich condition.
This is why no 1.8Ts have blowoff valves installed on them. There are, however, diverter valves being used that do away with the rubber bladder in favor of a metal piston. The stock DV can't handle the higher boost pressures of chipped cars.
-Cy
CP is offline
Old 02-25-2001, 01:40 AM   #7
SilverSubie
Member#: 4375
Post
So for a open atm. BOV to be used properly would you have to get a custom chip made or computer reprogrammed?or would using a Safc compensate for it?
SilverSubie is offline
Old 02-25-2001, 12:05 PM   #8
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
Go to this thread: http://www.i-club.com/ubb-files/Foru...ML/000384.html for some different opinions.
I have heard from numerous turbo owners with factory turbo cars( mostly DSM guys) that vent their BOV to the atmosphere with no problems, yet out of all the people who say you can't do it, I have yet to hear of someone damaging anything because of it. Not saying that it won't, but I would like to hear from someone with a bad experience from it.
Naturally, if the stock BOV is not strong enough to stay closed at idle, you are going to have problems, but with a good factory OEM( which I believe the later model ones used on the WRX are) or a good aftermarket one, still waiting for some proof why venting them to the atmosphere is so catastrophic.
Shik is offline
What Wheel Lug Pattern Does the WRX 02 Use? blindclown New England Impreza Club Forum -- NESIC 15 06-21-2002 02:13 PM
Does the WRX use the same oil filter as the 2000 2.5 RS? SuperFreq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-19-2001 02:58 PM
Does the new WRX use a MAF or a MAP sensor? BlazeYellowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2001 09:04 PM
Why does the WRX use a smaller displacement? Gvtec Normally Aspirated Powertrain 24 11-04-2000 07:27 AM
