Go Back   NASIOC > NASIOC Archives > NASIOC Archives > WRX Forum Archive
Old 02-24-2001, 11:57 AM   #1
SilverSubie
Member#: 4375
Exclamation nitrous benefits on turbo car...
Is it true using a small amount(25-35 shot) of nitrous on a turbo car will decrease intake temp drasticly and of course from that give you more hp from that. Where would you plumb it if you installed it(before the throttle body)? any opinions or thoughts would be great.
-grant
p.s. im talking about a dry system.
SilverSubie is offline
Old 02-24-2001, 04:14 PM   #2
JD LT4
Member#: 4459
Post
Hey SilverSubie... Guess who...
Just getting on here to check out some WRX stuff. I found a website earlier with some parts for the '02, but its all in Japanese, I'm trying to find a Euro site for you.
Later Grant,
JD
JD LT4 is offline
Old 02-25-2001, 12:06 AM   #3
SilverSubie
Member#: 4375
Post
-thanx
Old 02-25-2001, 12:13 AM   #4
BoostFreak
Member#: 4432
Post
I have never used nitrous, but have helped a friend install and tune a wet setup on his car(98 Regal GS). It is true that nitrous will give larger gains to forced induction engines due to thier relatively higher intake charge. But non-intercooled applications will see the best gains from a small shot of nitrous. On my buddy's 98 GS, he cut .4 off his E.T. with only a 25 shot.
Btw, if you plan on using a dry system, you have to install the nozzle before the MAF, so the PCM can compensate with extra fuel, or you'll lean out. That's why I wouldn't install anything but a wet system.
BoostFreak is offline
Old 02-25-2001, 12:19 AM   #5
SilverSubie
Member#: 4375
Talking
on my dry system it has a fuel pressure riser that attaches to the fuel pressure regulators vaccum line. supposively when you hit the nos it creates a vaccum and make the fuel pressure rise, but i have never used it. In that case i would think you wouldn't plumb it before the maf but after it.
-grant
Old 02-25-2001, 10:19 AM   #6
XT6Wagon
Member#: 524
04 STi
Post
Um, NEVER install nitrous before a MAF. Well unless you like converting a $200-300 MAF to scrap. These things run at several hundred degrees on the wire. Sudddenly you are runnign a very dense gas that is below freezing across it. Mmmm broken maf.
Just get a decent NOS system and follow the instructions.
XT6Wagon is offline
is there any laws in canada saying you can't use nitrous oxide on street cars? inpreza kid Canada Region Forum 19 01-19-2004 12:20 PM
2.5rs borla exhust on turboed car... nick robinson Normally Aspirated with bolt-on Forced Induction Powertrain 15 05-15-2003 09:24 AM
Transmission Fluid on Turbo car!!! impRSa01 Transmission (AT/MT) & Driveline 1 12-26-2001 03:15 AM
Insurance on turbo cars, Chai? nsotak North West Impreza Club Forum -- NWIC 2 02-24-2001 07:45 PM
UDP gains on Turbo Cars 2.5RSt'd Normally Aspirated Powertrain 2 11-13-2000 03:48 PM
