Old 06-10-2004, 02:16 PM   #1
speedypete
Member#: 62012
2004 FXT 5speed
Cobb stage 2
Default FXT stage 1&2 dyno #'s
check em out here
http://www.wrxforum.com/cgi-bin/ulti...?ubb=forum;f=6
mmm...310 lb/ft tourque
speedypete is offline   Reply With Quote
Old 06-10-2004, 06:41 PM   #2
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
They both look great.
270hp/285 lb/ft on 93 oct with only the AP.
Can't wait for the first user reviews.
Richard
SuperRuWRX is offline   Reply With Quote
Old 06-10-2004, 11:16 PM   #3
DRNWAGN
Member#: 44255
10 Scion TC
I looked at the charts and none of the curves go over the 250 mark on the graph. Yet they are saying 270hp. What am I missing here.
I think these are good set ups but since I am getting ready to add a turbo and different tmic this fall/winter I will be looking for their stage III or IV map. I know they have already been doing testing on it using a vf39 and sti tmic but I think I want something a little larger than a vf39 or at least a little nicer anyway. That will mean larger injectors and pump so tuning is a must.
DRNWAGN is offline   Reply With Quote
Old 06-11-2004, 07:19 PM   #4
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
The lower number is what was measured on the dyno at the wheels. The higher number is estimated flywheel output (without drive train loss). The flywheel figure is used for comparison to factory figures.
BTW, you can use the AP w/ a stage 1 map with your car now.
Then when you do major upgrades, all you will need to do is install an stage 2/3/or even higher map to match your new killer setup. Richard
gabedude's stage 1 dyno #'s boostdog Open Source Reflashes 8 08-12-2010 12:57 AM
Cobb Stage 2 Dyno #'s and Boost Question Jard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 10-31-2004 11:52 PM
My Cobb Stage 1 dyno #'s Drews_WRX Engine Management & Tuning 8 07-26-2004 09:12 PM
Cobb stage 1&2 dyno #'s speedypete Forester Forum 4 06-14-2004 12:26 PM
TurboXS stage 2 dyno #'s using stock muffler? blkwag Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 02-12-2002 07:46 PM
