Old 06-11-2004, 12:21 AM   #1
gaewsky1
Member#: 32017
2011 Outback
Default NOOB....UTEC map selector install
How easy to install and where should I run the wire?
Thanks.
gaewsky1 is offline   Reply With Quote
Old 06-11-2004, 09:15 AM   #2
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Very easy, run the cable above the tranny tunnel and mount the switch in one of the blank slots on the left of the steering wheel.
Then make sure you follow the directions and have the Map selector on the UTEC set to "0" and the switch set to "0" as well. Plug it in and you done.
now hooking up the launch control is a different issue.
M
bikerboy is offline   Reply With Quote
Old 06-11-2004, 02:48 PM   #3
gaewsky1
Member#: 32017
2011 Outback
Thanks,
I'm going to stay away from the launch control.
DIY: For Installing UTEC Map Selector Switch??? Rsxkiller UTEC 17 09-07-2006 10:06 PM
UTEC Map Selector Switch Help D_Block Engine Management & Tuning 0 10-22-2004 08:35 PM
CA: STi Utec + Map Selector dashiet Private 'For Sale' Classifieds 3 09-08-2004 01:55 PM
utec map selector needed. dothespeedlimit Private 'Wanted' Classifieds 2 07-23-2004 06:40 PM
Utec Map Selector.. WRX Jim Engine Management & Tuning 2 10-28-2003 03:47 AM
