#1 |
Member#: 34476
BAIC
Vehicle:88 civic subyless for now |
Heres the deal, the line going from the turbo to the wastegate blew off from the turbo and still was connnected to the wastegate. I don't know if it was hooked up right to begain with b/c I get compressure surge when I blow off and when I tried to turned my wastegate a while back to up the psi to 7 or 8 pounds, it stayed at 5. So I turned the wastegate back to where it was and left it that b/c I didn't need problems. So at 5 pounds tonight the line blows off at some point on the way home and I don't realize it until i pop the hood when i get home. I go to check the exhaust and notice there is a trail of oil leading into my driveway and right under the motor after letting it idle for about 2 minutes and there is about a 1/4 of a quart of oil on the ground I checked my exhaust to see if oil was coming out of it but it was dry. The motor is a 1.8 that has about 135k on it I don't know if this could possibly be my piston rings or what, PLEASE HELP?
#2 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
No oil in the exhaust is a good sign. Get a compression test to be sure. Wipe all the oil off of the underside and look for the fresh oil leak.
Brent |
#3 |
Member#: 34476
BAIC
Yah, thanks brent for the reasurrance, I will do that bright and early tomorrow morning but now I am beat, I need to go to bed
anyone else have any ANSWERS??? Last edited by ituner; 06-11-2004 at 01:00 AM. |
#4 |
Member#: 34476
BAIC
check my compression:
left side: 60, 85 right side: 120, 190 spark plugs were soaked in oil, looks like I will be doing a swap |
| Thread Tools | |
| Display Modes | |
| leaking oil!! please HELP! | ituner | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 07-04-2004 12:28 AM |
| I got me an oil leak! lil help | Turk | South East Region Forum | 7 | 04-19-2004 06:21 AM |
| Slow but steady oil leak, need help. | trilap5e | Service & Maintenance | 3 | 01-06-2003 02:42 PM |
| mysterious oil leak - need help | WRXIN | Factory 2.0L Turbo Powertrain | 7 | 01-03-2003 12:08 PM |
| MY99 RS Leaking oil...VERY worried...need help please | Aaron'z 2.5RS | Normally Aspirated Powertrain | 4 | 09-16-2001 01:49 AM |
