Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-11-2004, 04:13 PM   #1
ituner
Member#: 34476
88 civic
subyless for now
Default leaking oil!! please HELP!
Heres the deal, the line going from the turbo to the wastegate blew off from the turbo and still was connnected to the wastegate. I don't know if it was hooked up right to begain with b/c I get compressure surge when I blow off and when I tried to turned my wastegate a while back to up the psi to 7 or 8 pounds, it stayed at 5. So I turned the wastegate back to where it was and left it that b/c I didn't need problems. So at 5 pounds tonight the line blows off at some point on the way home and I don't realize it until i pop the hood when i get home. I go to check the exhaust and notice there is a trail of oil leading into my driveway and right under the motor after letting it idle for about 2 minutes and there is about a 1/4 of a quart of oil on the ground I checked my exhaust to see if oil was coming out of it but it was dry. The motor is a 1.8 that has about 135k on it I don't know if this could possibly be my piston rings or what, PLEASE HELP?
ituner is offline   Reply With Quote
Old 06-11-2004, 04:43 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I'm not sure if I follow............where is it leaking from??
Wedge is offline   Reply With Quote
Old 06-11-2004, 05:09 PM   #3
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Does the car seem to run ok? Where is it leaking from? Oil feed, oil return, front main seal, oil pan...????
Does the car idle VERY rough? does it run?
Chad
93 2.2T
subachad is offline   Reply With Quote
Old 06-11-2004, 06:31 PM   #4
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
find out where the oil is dripping from, follow it back from there. Where does it stop? If it is coming out that fast it should be easier to locate as you should be able to see it!
Hitokiri is offline   Reply With Quote
Old 06-15-2004, 02:00 AM   #5
ituner
Member#: 34476
88 civic
subyless for now
Well I ripped the motor apart down to the block and still can't find where it is leaking from. I checked the oil pan, oil feed and oil return and they are fine. I don't curerntly have a hoist right now so I can't check the rear main seal but I did a compression test and the left side is 60, 85 and the right side is 160, 190 and the plugs were soaked in oil, looks like i will be doing a swap a little sooner than I hoped too.
Old 07-04-2004, 12:28 AM   #6
97BlackSE
Member#: 45472
Default Re: leaking oil!! please HELP!
Way to answer your own question, you're doggin me, doggin me, doggin me!
97BlackSE is offline   Reply With Quote
Oil leak question. Please help! ajordan282 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2010 04:05 PM
Oil leak problem, Please help! roloc31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-19-2008 12:49 AM
Oil leak problem, Please help! roloc31 Newbies & FAQs 4 10-17-2008 09:50 PM
Oil leak problem, Please help! roloc31 Newbies & FAQs 3 10-09-2008 08:34 AM
dealer botched my fuel leak tsb, please help! no_rex_yet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-13-2004 05:21 PM
