Old 06-11-2004, 09:26 PM   #1
CTOESHO
Member#: 24962
05 STi
Default 2005 STi offset question
With the new 5x114.3 offset and 8" wide wheel stock on the new 05 STi, what offset can I run with aftermarket wheels? Can I run an 18x8 with a +37 offset?
CTOESHO is offline   Reply With Quote
Old 06-12-2004, 02:00 AM   #2
ChrisL2
Member#: 1444
37 is probably a little low. Posting in the Tire&Wheel forum would get you better responses.
ChrisL2 is offline   Reply With Quote
Old 06-12-2004, 08:44 AM   #3
jaypride
Member#: 33424
2004 STI
Blue/Gold
37 is pretty low and will most likely end up rubbing.
By going with 18's you can probably get a higher offset tha you would with 17's.
You want to be as close to the factory 53 offset as you can. Your bearings will thank you.
jaypride is offline   Reply With Quote
Old 06-12-2004, 11:43 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
55 -37= 18mm or ~3/4 of an inch ...it might rub depends heavely on what tire you use..but will definatly be hard on your wheel bearings
2005 STi immobilizer question/ Engine in a non-Subaru chassis Schimke Subaru Conversions 31 02-26-2012 06:52 AM
STi offset question digitalmediapro Tire & Wheel 3 05-03-2007 10:28 PM
2004 v. 2005 STi axleback question REX8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 04-19-2006 10:45 PM
2005 Sti Tire question flicky30 Newbies & FAQs 2 12-03-2004 01:33 PM
2005 STi Suspension Question ProjectSTI General Community 2 06-17-2004 11:45 AM
