Old 06-11-2004, 11:14 PM   #1
slvr bullet
Member#: 52400
2004 WRX Wagon
Platinum Silver Metallic
Subaru Stars 04 STi sways in an 04 wagon
I have been searching around for a while trying to find any info on this so forgive me if this question has been asked before I and couldn't find it using the search button. Was wondering if the sway bars from the 04 STi's fit on the 04 Wagons? I am assuming I may need new busings or or brackets if it is even the correct shape. My buddy upgraded his STi's sways to thicker bars so I'd like to get his stock ones if they will work out!
Thanks Much.
slvr bullet is offline   Reply With Quote
Old 06-12-2004, 12:07 AM   #2
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
for the rear you need, the sti bar, bushings, endlinks, and lateral links. it's expensive and not really worth it since a 20mm sedan bar can be had for like $50 used or about $75 for a new one
the front bar won't fit either unless you swap the control arms out for sedan ones and some other expensive parts...just buy a whiteline bar for like $125
b_tapper is offline   Reply With Quote
Old 06-12-2004, 12:11 AM   #3
slvr bullet
Member#: 52400
2004 WRX Wagon
Ok cool thanks
Old 06-12-2004, 12:19 AM   #4
slvr bullet
Member#: 52400
2004 WRX Wagon
That actually brings up a second question.... what is needed to use a 2004 (or even 2003?) 20mm Rear sway.... or is it just less hastle to buy an aftermarket whiteline cobb or the like sway?
Old 06-12-2004, 01:01 AM   #5
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
nothing... just swap it in there.
Rebellion is offline   Reply With Quote
Old 06-12-2004, 08:28 AM   #6
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
mid-'03 to '04's come with a 17mm bar. the '02-early'03's come in the 20mm.
just get the bushings with the 20mm bar. i have a 20mm from a '03 and love it
Quack is offline   Reply With Quote
will 04 sti sway bars fit 04 wrx and is it considered an "upgrade" MAtwal Transmission (AT/MT) & Driveline 1 01-22-2010 12:06 AM
04 sti bumper on an 04 wagon mbscooby129 Interior & Exterior Modification 16 04-30-2009 10:24 AM
05+ STi Center in an 04 STi Admission_Regret Interior & Exterior Modification 1 09-12-2008 04:25 PM
05 STi Seats in an 03 Wagon Pugster Electrical & Lighting 2 02-07-2007 06:52 PM
04 JDM Sti headlight in an 04 2.5 RS? digi Interior & Exterior Modification 11 11-30-2003 05:18 AM
