Old 06-12-2004, 01:02 AM   #1
thechase
Member#: 61737
2004 WRX STi
Default UTEC on JDM ECU
I tried searching and asking in other forums but for some reason no one knows so once again i trust you guys and you always seem to come through for me. So here it goes. Does anyone know if the UTEC will work on JDM version 8 ECU's? Or will i need a JDM version of UTEC? It's a simple question but all i've been able to come up with is "maybe".
-Chase
thechase is offline   Reply With Quote
Old 06-12-2004, 10:01 AM   #2
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
I replied in your other thread, so here is a repeat.
YOU DEFINATELY need the AUS/JDM STi UTEC. You should be able to get one from TurboXS here, although when I got mine Nathan implied that they do not always have them in stock. Give them a call and tell them what you are planning and Either Nathan or Germaine will let you now what all you need, and if they have it.
pegdrgr is offline   Reply With Quote
Old 06-12-2004, 12:23 PM   #3
thechase
Member#: 61737
2004 WRX STi
Thanks pegdrgr!
Old 06-13-2004, 10:52 AM   #4
Richard Sierra
Member#: 29528
02 WRX wagon V7 RA
-C conversion
Not correct, I have the US WRX UTEC on a RA ECU, it works fine.
You do have to directly wire the AVCS wiring (if you are using it) into the ECU instead of the UTEC.
Richard Sierra is offline   Reply With Quote
Old 06-13-2004, 12:28 PM   #5
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
You are better off with the JDM STi UTEC. If you are going to buy one this is the UTEC to get for this setup. I will not say anything more than that.
Old 06-14-2004, 07:39 PM   #6
Richard Sierra
Member#: 29528
02 WRX wagon V7 RA
-C conversion
No question the JDM UTEC is best if you must buy one. To say you "DEFINATELY" need one is misinformation.
Old 06-14-2004, 07:59 PM   #7
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
Agreed that it was misleading, although I still say you "Definately" need it. Yes you can get around it, but anyone ordering a UTEC for this purpose Definately NEEDS the JDM/AUS STi UTEC.
Old 06-15-2004, 06:22 PM   #8
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I run the Rev 6b US WRX Utec on my JDM Type RA Spec C ECU.. It works perfectly. Older Utecs did not have all the pins on the connectors. Later versions had the pins and passthrough signals. If you have a Rev6 Utec you are fine.
C
AZScoobie is offline   Reply With Quote
Old 06-15-2004, 10:30 PM   #9
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
For pass through, yes.
Edit for spelling
Old 10-09-2005, 02:19 PM   #10
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Im bringing this back from the dead
What would be the difference between running the JDM UTEC and running a newer WRX UTEC??? If there is no difference other then the codes for the injectors then why spend a lot more on the JDM?
I called TXS and they said the JDM UTEC doesn't allow control of the AVCS, so why bother spending the extra $$ for no difference in performance?
LIQUIDSK8S is offline   Reply With Quote
Old 10-09-2005, 05:23 PM   #11
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
CEL = failed emissions testing in certain states.
DoctorNick is offline   Reply With Quote
Old 10-09-2005, 05:54 PM   #12
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yet another reason im thankful to live in Fl.....no emissions and we get 93 octane
Old 10-09-2005, 10:58 PM   #13
ejh25
Member#: 65267
Are you saying that the JDM Utec on a JDM ECU has a lesser chance to through a CEL than a USDM WRX Utec on a JDM ECU?
ejh25 is offline   Reply With Quote
Old 10-10-2005, 12:29 AM   #14
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I believe so. Am I wrong to say this?
Old 10-10-2005, 12:34 AM   #15
cronic
Member#: 9749
If you run the US utec on the JDM ecu you get four injector codes. The JDM Utec fixes that.
Dave-
cronic is offline   Reply With Quote
Old 10-10-2005, 11:06 AM   #16
ejh25
Member#: 65267
Dave-
Thanks for the clarification.
How to CEL on JDM ECU mathroch Subaru Conversions 11 08-22-2006 02:48 PM
rev 6 utec on jdm ecu ImprezaRSfan! Engine Management & Tuning 3 11-02-2004 05:37 PM
rev6 utec on jdm ecu ImprezaRSfan! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-02-2004 04:05 PM
pulling codes on jdm ecu ImprezaRSfan! Subaru Conversions 20 07-15-2004 12:52 PM
anyone have a pict of UTEC on the ECU? kenchan Engine Management & Tuning 4 02-21-2003 06:38 PM
