Old 06-12-2004, 01:17 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default coolant lines on td04
Do i really need to run coolant lines to the turbo if im only going to run 8 psi?
NeaD is offline   Reply With Quote
Old 06-12-2004, 01:19 PM   #2
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
If its not oil cooled... then yes... if you dont you will over heat it... even at only 8PSI, the propeller spins at something like 30,000 RPM or something really high...
masiolli is offline   Reply With Quote
Old 06-12-2004, 11:09 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default spooling
thats a definate 10-4
like he said....turbos spin @ up to 100,000 RPM thats alot of heat!
IllNastyImpreza is offline   Reply With Quote
TD04 WG Actuator, Coolant Lines, Oil Retun Line STI Thermostat BlackFlame Engine/Power/Exhaust 4 11-28-2008 10:50 PM
Coolant line on turbo Oas1s Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-02-2007 06:09 AM
need help with coolant lines on a perrin rotated kit 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-11-2007 12:29 PM
Tips for removing lower coolant line on turbo? proletariandan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-09-2007 11:50 PM
TD04 Oil & Coolant Line Questions WRXRgr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-12-2005 10:34 AM
