Old 06-12-2004, 09:42 PM   #1
awd4ever
Member#: 31573
I found the
meaning of life!
Default Something blew, not sure what
Hi, last night on the way home my car started making a hissing sound. Interesting thing is, this happened when car was not being pushed hard, if at all.
Car idles normal, no RPM spikes, but at idle it's making sound like something is clanking inside the block. Thought i blew the SC, but after removing the belts clanking continued. Under boost the car sounds like it's leaking mass boost and it seems quiet a bit weaker.
Initial ideas:
Crank bearing or bent valve.
Setup:
98 block (130k), new style HG
5psi on supercharger
J&E, S-AFC, valbo...
Thoughts?
awd4ever is offline   Reply With Quote
Old 06-12-2004, 11:59 PM   #2
awd4ever
Member#: 31573
I found the
meaning of life!
Checked compression, comes back fine:
right side: 195, 195
left side: 185, 182
Prolly a bearing... hate taking the block out again
Old 06-13-2004, 12:03 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
Need EM solution...
Default block
time for an ej22t
IllNastyImpreza is offline   Reply With Quote
Old 06-13-2004, 01:45 AM   #4
awd4ever
Member#: 31573
I found the
meaning of life!
you know... i was not impressed with the numbers at 16 psi. Actually, i was dissapointed. I would have expected a 2.2 @16psi to push over 300.
Old 06-13-2004, 02:21 AM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
Need EM solution...
Default block
the block is wicked heavy...its meant to handle ALOT more boost than that. 25 PSI ALL DAY LONG on stock internals...slap new rods in there and your talking 30+!.....RELIABLY
Old 06-13-2004, 02:54 AM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
maybe with a monster lagy turbo. 16psi is not much at all. Guys on legacy central have been running 22psi for daily driving for years now.
subiekid is offline   Reply With Quote
Old 06-13-2004, 10:46 PM   #7
awd4ever
Member#: 31573
I found the
meaning of life!
So, we got a little update.
I drove the car for a bit today, and the sound went away. Now we all know broken bearings dont go away, so i think a piece of gasket or a small rock got sucked in from the header side.
Long story short, i was going to replace my headers, new one didnt fit, so i plugged old ones with old gaskets... possibly it broke, and piece was wobbling in the combustion chaimber.
Is there a way to determine if any of the valves are bent?
...it would suck to remove intake mani, as i have a supercharger...
Thanks
Old 06-14-2004, 08:58 AM   #8
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
If the compression test came good the valves must be ok!!
Elliot is offline   Reply With Quote
Old 06-14-2004, 10:17 AM   #9
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
hey, what kind os sc setup do you have? and where you at? might be able to swap ideas. i'm currently having engine probs. i'm loosing 5psi somewhere. and my engine is quite tired. - IC
IdenityCrisis is offline   Reply With Quote
Something broke- but not sure what madmax718 Service & Maintenance 13 02-09-2009 06:23 PM
Need something... not sure what its called Pick9811 Electrical & Lighting 8 05-24-2008 08:05 PM
Exhaust rattle or something else....not sure RoadTrippin Service & Maintenance 1 04-26-2008 06:14 PM
Not sure what this part is called... but damn sure hard to find! Skin Irritant Newbies & FAQs 28 01-09-2008 05:15 PM
Did something to the impreza and not sure what nutrigrainkiller Newbies & FAQs 2 03-12-2006 07:28 PM
