Old 04-09-2001, 01:35 AM   #1
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
Angry Fogging Windows
Every time it rains, my the windows in my car instantly fog up. The only way that i can prevent this is to turn on the heat. The fog goes away but i get hella hot and start to sweat. My sweating then fogs up the windows and there's nothing i can do once that happens. Have any of you experienced this? Do you have and solutions?
KillerTHC is offline   Reply With Quote
Old 04-09-2001, 01:38 AM   #2
Andrew
Member#: 1170
2005 STi
Post
Do you have the air on recirculate?
Andrew is offline   Reply With Quote
Old 04-09-2001, 03:32 AM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
hmmm.... i know the last time i did but im not sure about the other times. what should i have it on?
Old 04-09-2001, 03:39 AM   #4
Digital_Boy
Member#: 730
Post
Try running the A/C. This will dry out the air in the cabin.
I think running the AC on recirc for awhile will dry out the cabin air. But it also allows the condensor to accumulate water, which can mildew and cause serious funkage when you use AC.
Digital_Boy is offline   Reply With Quote
Old 04-09-2001, 03:52 AM   #5
s
Member#: 5376
1999 Impreza 2.5RS
Post
try to clean the cabine side of the window also.. It helps me to clear the fog better after I wipe all the tar and dust off.
s is offline   Reply With Quote
Old 04-09-2001, 07:50 AM   #6
Norb
Member#: 4856
2002 WRX Wagon MT
Post
Just run the a/c button, even when in heater mode, and make sure to turn off recirculate. Its the biggest mistake most people make, they leave the recirculate switch on. Read the manual, it says not to leave it on, only use it to quickly cool the interior. I think its on the air flow rotary switch too, a reminder to have fresh air on during defogging.
Norb is offline   Reply With Quote
Old 04-09-2001, 08:53 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Exclamation
the guys are right...
run w/the AC on... neat little trick
also..
wash the inside windows frequently... this helps reduce fogging.
j. www.subiegal.com
Old 04-09-2001, 09:14 AM   #8
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Post
I got some of that rain-x defogger liquid. It works great. Havent had a problem since I applied it.
Tkacik is offline   Reply With Quote
Old 04-09-2001, 09:16 AM   #9
J Colman
Member#: 1259
1999 Impreza RS
Rally Blue Pearl
Post
Make sure the air is coming from outside the car. Wind down the window and that will make it go away also.
Justin
J Colman is offline   Reply With Quote
Old 04-09-2001, 09:22 AM   #10
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Post
Find somewhere else to make out!
Mike Smith is offline   Reply With Quote
Old 04-09-2001, 09:23 AM   #11
J Colman
Member#: 1259
1999 Impreza RS
Rally Blue Pearl
Post
Old 04-09-2001, 10:11 AM   #12
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
If you hit the defrost button and turn on the AC then it switches to 'defog mode' or at least that is what my manual says.
And I have lousy allergies so I leave it on recirculate all the time. I need to get that extra cabin filter thingamajig.
remarcable is offline   Reply With Quote
Old 04-09-2001, 10:40 AM   #13
Yotsuya
Member#: 935
Jack Soo Fan Club
Post
Just keep the air on recirculate, and the vents pointed at the windows. I've never had serious fogging problems with the Impreza in any season. The key is to keep the windshield as warm or warmer than the outside air. This will keep condensation off the window. The only fog problems I've had are in the summer when I have the AC blowing on the windows (I don't like it in my face) and some frost builds up at the base of the windshield.
Yotsuya is offline   Reply With Quote
Old 04-09-2001, 10:46 AM   #14
dib123
Member#: 1835
Post
Another thing is if you have a new car the inside of the windshield has a greese like film on it. Don't know what it is for but if you get some windex it will take it right off and you shouldn't have any problems. I had the same problem for the first month of my car until I cleaned the interior.
dib123 is offline   Reply With Quote
Old 04-09-2001, 12:02 PM   #15
Norb
Member#: 4856
2002 WRX Wagon MT
Post
DON'T leave recirculate on, as stated above it will promote algea and mold on your condenser and if there is a carbon monoxide leak, there will be no way to expell it. BTW how can recirculate help your allergies, its the same air as outside just recirculating.
Window will roll down but not up!? GoneSingle Electrical & Lighting 2 08-04-2010 01:50 PM
1997 Outback Sport fog light help 1997OBS Interior & Exterior Modification 1 06-01-2010 08:09 PM
06-07 fog light kit dazedone Exterior/Styling 7 06-01-2010 05:26 PM
('93-'01) Window fogging problem? Skirvdawg Impreza Forum 9 05-11-2001 08:03 AM
