Old 06-14-2004, 02:31 PM   #1
silletti
Member#: 58732
2012 STi
Silver on order
Default this might sound crazy but...
has anyone tried using a miniature jet engine from an r/c plane to keep the turbo constantly spooled? i'm thinking that it can be placed so that its exhaust gas can be fed through the uppipe into the turbo. i checked the egt of the small jet engines and they are in line with the egt experienced in a stock wrx.
in a way, it's like supercharging your car without drawing power from your engine and without needing to drop the clutch from a high rev.
these engines run on kerosene, so a seperate fuel system would be needed.
just an idea. let me know what you think.
silletti is offline   Reply With Quote
Old 06-14-2004, 02:47 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i dont think that little thing is gonna overcome pushing all that air and keeping the bov open because to constantly having it spool ud have to be venting a lot of air
Old 06-14-2004, 02:49 PM   #3
8Complex
Member#: 922
04 FXT
Red
A supercharger would be much easier. Instant boost, and no hassles of having to mess with the jet engine that just keeps the turbo spooled. It'd also be annoying as hell listening to that BOV recirculating constantly.
Old 06-14-2004, 02:49 PM   #4
silletti
Member#: 58732
2012 STi
Silver on order
some of these engines create 45 pounds of thrust. that's not enough?
Old 06-14-2004, 03:02 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
how big r they?
Old 06-14-2004, 03:05 PM   #6
silletti
Member#: 58732
2012 STi
Silver on order
about 5 1/2 inches in diameter.
http://jetcatusa.sitewavesonline.net/p200.html
Old 06-14-2004, 03:09 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Maintenance interval: 25 hours
those things DRINK gas maaaan
Old 06-14-2004, 03:10 PM   #8
8Complex
Member#: 922
04 FXT
Red
Sure, but you need to have the volume, as well.
Old 06-14-2004, 03:47 PM   #9
silletti
Member#: 58732
2012 STi
Silver on order
if it's producing that much thrust, shouldn't there be plenty of volume flowing?
gas consumption is pretty high at WOT. i wonder what it would be at 3/4 throttle or so. one gallon of kerosene would operate it at WOT for more than 5 minutes.
i don't think it would be practical for constant use, but in certain applications, i bet it would work. something you can switch on and off and adjust the power. maintanance wouldn't be that bad then.
Old 06-14-2004, 05:49 PM   #10
silletti
Member#: 58732
2012 STi
Silver on order
opinions, please!
Old 06-14-2004, 06:35 PM   #11
8Complex
Member#: 922
04 FXT
Red
Sure, but that is with a full open outlet. I doubt there are numbers out for that thruster that measure how much volume it outputs when you restrict the outlet, and at what pressures it can output those volumes.
It's 5.12" in diameter at the full body area, not at the outlet.
It's also producint 45lbs. of thrust, not 45PSI. That means that it would push against something at 45 lbs. of force.
Old 06-14-2004, 10:37 PM   #12
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
ahha, man, some people think of the stupidest things. This has to be one of the top 10 that I have seen.
I thought with those you had to use a nitro blend? my r/c plane runs off a nitro blend, but its not a mini jet.
subiekid is offline   Reply With Quote
I might sound crazy but would this work? WRXSteye20008 Newbies & FAQs 9 05-29-2008 01:00 PM
I know it sounds crazy, but.... upnygimp Off-Topic 10 01-11-2007 09:26 PM
This might sound weird...does anybody want a pictus catfish? DoinkMobb South East Region Forum 9 03-07-2006 01:50 PM
This might sound stupid but, how do i tell if a gear is grinding popnfresh Transmission (AT/MT) & Driveline 8 04-09-2005 03:05 PM
Message Board Statistics All times are GMT -4. The time now is 10:34 AM.
