Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 06-14-2004, 05:04 PM   #1
yellowsubaru
Member#: 59876
1985 subaru GL
tanish yellow
Default i broke a CV
it totally sucked, i was on the way to the store to get some oil, and as i was running a stop sign, turning and revving the engine way hard and my CV just snapped off at the wheel end, i just replaced this thing like a month or so ago, oh well at least i get a new one for free, and the tow only cost me 20 bucks.
thats my buddys 88 in the background.
yellowsubaru is offline   Reply With Quote
Old 06-14-2004, 05:27 PM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Bummer.. if its 4wd, you just put it in 4wd and drive home (gently).. no towing bill then
Calebz is offline   Reply With Quote
Old 06-15-2004, 05:20 PM   #3
yellowsubaru
Member#: 59876
1985 subaru GL
tanish yellow
well after further inspection i found out that the CV was working, but the hub that it goes into on the wheel end of the CV had its splines stripped out(bummer), so if anyone in the portland vancouver area has the hub for a 1985 subaru GL front wheel drive only, and doesnt need it, i do.
Old 06-15-2004, 05:33 PM   #4
Calebz
Member#: 54398
1980 CB400 Hawk
the hub from any EA82 L series car will work. 2WD or 4WD, Turbo or nonturbo. 85-94.
That may help your search. You are in the land of soobs.
Go over to www.ultimatesubaru.net , register and post a want ad in the marketplace.. I bet in less than 24 hours you will find someone local (between seattle and portland) that can hook you up for cheap. I'll see if I can get ahold of Mark in Olympia..I'm sure he has one.
Old 06-17-2004, 05:58 AM   #5
yellowsubaru
Member#: 59876
1985 subaru GL
tanish yellow
fixed it, i got one from a local bone yard, i think it was off a 90 loyale, anyway it works im happy.
Broke Rear CV Joint SloRice Transmission (AT/MT) & Driveline 4 06-19-2005 07:54 AM
CV joint spilling out grease !! clip broke.... KnightWRX Transmission (AT/MT) & Driveline 1 02-12-2005 03:34 PM
cv joint just broke iam stuck at work!! grndc2gsr Southern California Impreza Club Forum -- SCIC 26 12-05-2003 06:36 PM
cv joint just broke iam stuck at work!! stephenmeade Off-Topic 0 12-04-2003 07:27 PM
CV boots broke SharP Normally Aspirated Powertrain 3 09-12-2003 03:16 PM
Message Board Statistics All times are GMT -4. The time now is 09:37 PM.
