Old 06-14-2004, 06:26 PM   #1
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Default A grommet for a huge 1.5 inch square sensor
I need to pass my O2 sensor plug through the firewall. .. are there no grommets that are big enough for a 1.5 sq inch plug?
HOK is offline   Reply With Quote
Old 06-14-2004, 08:23 PM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Check the grommet directly below the steering column in the drivers side footwell... you need to peel back the carpet slightly, should be large enough.
no-coast-punk is offline   Reply With Quote
Old 06-14-2004, 09:30 PM   #3
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
your talking about the one behind the grake pedal right?..
i tried that one its JUST not bigg enough... i was so peed.. i don't want to break the plastic on the sensor...
you think if i cut the 5 wires adn resoder them it will be ok?
Thks
Old 06-14-2004, 09:48 PM   #4
no-coast-punk
Member#: 49087
Absolutely do NOT cut/re-solder any wires having to do with 02 sensors. One thing you could try (that might sound a bit scary) is to get a peice of re-bar, and ream out the hole for the grommet until it is large enough, then use a flathead screwdriver and hammer from the other side to get the hole back to normal size.
Old 06-14-2004, 10:04 PM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
you can CAREFULLY release the terminal locks, pull out the terminals and wires, and feed just the wires through any old grommet. Then simply reinstall the terminals/wires in the correct locations.
yamarocket630 is offline   Reply With Quote
Old 06-14-2004, 10:09 PM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
wuuuuuu good one...
thanks that way better then bash and slash.. hehe.. thanks guys..
btw how about that big hole just below the driver side dash. there was a plastic covering there but when i peeked in it just seemed to go into the rain ducts below the glass... is there a way into the dash or car from there?
Old 06-14-2004, 10:34 PM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Ugg, i hate getting wires out of plug ends. But that seems like the best idea, if you dont have any other place to run it.
subiekid is offline   Reply With Quote
Old 06-14-2004, 10:49 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
no coast ***?
y not just use a grinder
Old 06-15-2004, 03:13 AM   #9
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
HOK - the simplest way to feed that WB02 sensor is on the passanger side tranny tunnel area just in front of the shifter assembly.... drill a hole in the tunnel area to pass the plug through. This spot will allow you to either plug it into either one of the O2 sensor bungs (before or after the cat).
Or you can try finding the moisture/water drain tube that goes from the inside of the cabin out through the firewall.
GTBGUY is offline   Reply With Quote
Old 06-15-2004, 10:17 PM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
whats the reason I can't resolder the wires.. how much of a signal will i lose?
Old 06-15-2004, 10:19 PM   #11
subiekid
Member#: 25516
I think its an issue of adding resistance to the wire, this would cause a bit of delay, but i really dont think its that big of an issue.
Old 06-15-2004, 11:16 PM   #12
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Actually, it's because the sensor element needs an oxygen reference, I gets that by capilary action through the wire. Soldering the wires greatly slows down that action.
Old 06-16-2004, 12:07 AM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
What kind of % or other measurement are we talking about? will it delay it by double?
I just don't to start messing with the firewall as things rust up here pretty quickly...
do you guys know what grommet I'm talking about that is by the windshield on the driver side?
Old 06-16-2004, 01:28 AM   #14
subiekid
Member#: 25516
I am not feeling the Capillary Action explanation. The signal gets sucked up the wire?
Old 06-16-2004, 04:50 AM   #15
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Where did you two learn about electronics???
Unless the wires are shielded (they may well be) or they have a specific impedance or something (that may be the case) there is no worry about soldering them.
Solding wires will not change the amount of time it takes for a signal to get through the wire. Soldering correctly will not add to the resistance of the wire. The oxygen reference for an O2 sensor comes from the back side of the sensor itself, not the wires.
All that said, I think your best bet is to pop out the wires directly at the connector as suggested above.
-Charlie
phattyduck is offline   Reply With Quote
Old 06-16-2004, 06:21 AM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
jesus christ
thats like my friend when he wired his neon lights backwards and had the switch set to ground out the circuit, i flip the switch and light up half his dash <by light i mean the wire caught on fire> i was like you idiot and hes like DUDE dont you know anyhting about electronics? the energy backfires up the wire and it fried itself thanks!
Old 06-16-2004, 12:31 PM   #17
subiekid
Member#: 25516
-Charlie
Well I have only taken one basic class for electronics, and the instructor was from another country, so I really didnt get anything out of that class. I was just curious on why you couldnt cut and solder the wire. Thanks for the explanation.
And White 2.5rs this is not wirering lights on your ghay friends cars.
Old 06-16-2004, 12:38 PM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
E@+ mine arse
Old 06-16-2004, 12:39 PM   #19
Aphex
Member#: 146
'16 WRX Limited
O2 sensor wires are shielded. which is why they cannot be cut and resoldered. What's on the other end of the plug? would it be possible to run it the other way?
for that hole I believe that is just for access to the wiper assembly and you cannot get into the cabin from there. and if you did, your wires would be running next to the wiper assembly and most likely would get cut.
and yes, white2.5rs what did that have to do with anything, besides general electrical incompetency? it added nothing to this thread that's for sure.
Aphex is offline   Reply With Quote
Old 06-16-2004, 01:07 PM   #20
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Originally posted by White 2.5rs
E@+ mine arse
Enough. Next stupid post and you get more points. End of story.
kastle is offline   Reply With Quote
Old 06-16-2004, 01:08 PM   #21
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
neither did whats his names post of making fun of my friend
Old 06-16-2004, 01:15 PM   #22
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
That was directed not only to you but everyone in the thread. I'm sorry if you took it personally.
Old 06-16-2004, 02:50 PM   #23
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
sorry kastle you quoted something i said and said "you"
hella
Old 06-16-2004, 08:51 PM   #24
subiekid
Member#: 25516
Okay, I have another serious question.
So if the wide band ego is shielded, then it should not matter if its ran next to other wires that are for my TEC 3? Would it be best to keep it away from all my other wires? Do I need to wory about cross talk, or anything else?
Old 06-16-2004, 09:35 PM   #25
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
here is the link to exactly what i'm talking about...
http://www.hokman.com/hok/images/car/hydraharness.JPG
I didn't post as IMG because its a repost... but what it shows is the O2 wires. The other end is already attached to the wiring harness of the 2.5 RS harness. I was thinking at the other end of the plug where the black shrink wrap is that I can resolder it there. doesn't seem shielded there.
I can take more photos if need be...
TIA
wheel alignment for 1.5 inch drop... devasta Brakes, Steering & Suspension 0 04-05-2010 11:48 AM
Older Legacy 1.5 inch lift. roostema4328 North West Impreza Club Forum -- NWIC 7 05-13-2008 09:12 PM
wtt: my scoobysport axleback for your stromung 2.5 inch axle back WrexFactor36 SCIC Private Classifieds 0 09-08-2006 12:26 AM
WTT: APS 3 inch for your APS 2.5 inch muffler subaru_wrxwagon SCIC Private Classifieds 5 04-04-2006 08:17 AM
I'm looking for a cheap 2.5+ inch exhaust (used) Chav Mid Atlantic Impreza Club -- MAIC 1 08-09-2002 01:53 PM
