Old 06-15-2004, 02:59 AM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Default What is your EGT and Oit temp read?
my EGT read around 650-700c and oil temp is around 100-110c during cruze i think it kindna high, is it? what is your EGT and Oil temp?
ChAi is offline   Reply With Quote
Old 06-15-2004, 07:47 AM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
that is pretty low for EGT actually
700c = 1292F
I max at about 1400F NA so you should be higher. Where is your probe installed? Mine is 4" out of cylinder 4 (closest to driver).
Todd
Hitokiri is offline   Reply With Quote
Old 06-15-2004, 01:18 PM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
My EGTs read ~750C going ~75 mph.
cRayZee is offline   Reply With Quote
Old 06-15-2004, 01:32 PM   #4
ChAi
Member#: 1277
1999 Minnam Stage 2
700c = 1292F
Todd
i install it on the bolar header when cylinder #1 and #3 came togather on header
Old 06-15-2004, 10:17 PM   #5
kaos200
Member#: 2692
is your car running now?
Ive been getting anywhere from 720-800 during cruise, but Ive tuned it down now so it stays from 700-750.
kaos200 is offline   Reply With Quote
Old 06-15-2004, 10:25 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
1400-1500F highway cruise. 75-80mph.
oil temp is useless. IMO.
Jay
Old 06-15-2004, 10:48 PM   #7
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Cruising EGT is a little on the low side. Are you running rich at all?
Old 06-15-2004, 11:19 PM   #8
kaos200
Member#: 2692
Jay
Its real useful if you road course the car
Old 06-16-2004, 02:01 AM   #9
ChAi
Member#: 1277
1999 Minnam Stage 2
Did the map work? how is your car
Old 06-16-2004, 04:54 AM   #12
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
For reference, a stock WRX runs about 1200-1250*F at a 70mph cruise and about 1300-1350*F at 80mph cruise. (oh my car, at least)
Cooler/hotter EGTs might also be due to timing differences on the Link vs. a stock ECU at cruising. Maybe something to look at?
-Charlie
phattyduck is offline   Reply With Quote
Old 06-16-2004, 05:18 AM   #13
kaos200
Member#: 2692
-Charlie
nice and rich I see.....
Old 06-16-2004, 11:20 PM   #14
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
touché!!
Jay
Old 06-16-2004, 11:30 PM   #15
phattyduck
Member#: 32955
'03 WRX Wagon
I always thought it was because I drive slow?
Actually, those readings are in the uppipe, so they are a bit cooler than you might see at the cylinder outlet...
Old 06-17-2004, 12:15 AM   #16
kaos200
Member#: 2692
ahh there it is!
Post your EGTs and where your probe is tapped Help! (REDO) Noize Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 06-04-2016 02:34 PM
What is your Water Temp running... Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-12-2004 12:53 PM
What are your EGT readings @ Idle? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-21-2003 01:41 PM
What is your Oil Temp? cantex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-12-2002 10:17 PM
