Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 06-15-2004, 08:34 AM   #1
gc8ej20
Member#: 43780
1998 RS
Default wrx swap starting problem
almost finished my wrx swap but when i go to start the it just keeps cranking and not kicking over the thing i noticed is that the fuel pump doesn't even sound like it kicks on you dont hear it and then when i checked the voltage on the fuel pump connecter it was reading about 6 volts can someone help me? is there something im missing in the wiring why this is hapening?
gc8ej20 is offline   Reply With Quote
Old 06-15-2004, 12:33 PM   #2
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
welcome to the club
ImprezaRSfan! is offline   Reply With Quote
Old 06-15-2004, 12:35 PM   #3
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
You have the fuel pump controller hooked up right???
imprezaclipse is offline   Reply With Quote
Old 06-15-2004, 02:44 PM   #4
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
u dont need a fuel pump controller. I wasted 80 bucks on one
Old 06-15-2004, 04:37 PM   #5
gc8ej20
Member#: 43780
1998 RS
imprezarsfan! so did you fix your starting problem or are you still having similar problems as i am
please need help quick as possible miss driving my RS so close to finishing her
Old 06-15-2004, 04:40 PM   #6
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
still havent started it up yet
Old 06-15-2004, 05:07 PM   #7
gc8ej20
Member#: 43780
1998 RS
imprezaclipse no don't have a fuel pump controller
Old 06-15-2004, 05:51 PM   #8
Structure828
Member#: 50488
1999 GC8 ej20g!
You should not need a fuel pump controller. Depending on what model motor/car you have and what your putting in, there is usually a fuel pump relay. The relay itself could be bad.
What it sounds like to me is you are not getting the correct voltage which can mean 2 things....
You either have bad grounds or the power source you are tapping into is not correct.
If I remember correctly the fuel pump requires 12v full power source. (Check your diagrams first I dont want to be liable)
Make sure to CLEAN all your ground wire points and any ground the fuel system has. Simply resurfacing the area can literally make it work or not turn on.
2nd, after you check your grounds, make sure you are tapping into the correct power source. I believe the Fuel pump can be linked to the starters power source. Give that a try, or PM me with more details.
Structure828 is offline   Reply With Quote
Old 06-16-2004, 08:59 AM   #9
gc8ej20
Member#: 43780
1998 RS
thanks structure828 gonna try this later today after i get out of work
Old 06-16-2004, 09:18 AM   #10
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Not sure how you guys are bypassing the contoller unit,but I used one and my car fired up on the first try.
post swap electrical starting problems Odeaten Electrical & Lighting 2 04-18-2010 10:40 PM
wrx swapped gc problems (fuel keeps topping off and cel) wrc-driver Subaru Conversions 2 12-17-2009 01:35 PM
1995 subaru legacy l with 2002 subaru wrx swap wiring problem hybridpatient95 Subaru Conversions 1 05-29-2008 07:43 AM
'06 STI swap - starting problems SOLUTION Service & Maintenance 3 03-04-2007 10:56 PM
RS to Wrx swap speedo problem Rdwrc Subaru Conversions 8 07-26-2006 12:36 PM
